HELP I mistyped the confreg variable in ROMMON
sticano
I typed confreg 0x2124 and reset my 2811 and now the characters are not recognizable. How do I undo this mistake?
8 Replies 8
viyuan700
Level 5
Level 5
in 0x2124 mode console speed is 19200 so select speed 19200 instead of 9600 in hyperteminal.
Then you can reset it again.
that was it. Thanks..
I typed 0x21142 in my Cisco 2811 confreg,
do you know the solution?
The output shows nothing but CCCCCCCC (but the C is in the French version with the comma under the letter C).
Solution found:
Baud rate = 2400.
I'll need your help please!!
I mistyled the confreg as: 0x1242
Please suggest solution.
SachinKotian
Hi Viyuan700
SachinKotian
Hi Sachin,
Please check the link below and had the solution. As per them you need to set Baud Rate to 1200.
https://supportforums.cisco.com/discussion/11593861/cisco-2600-router-confreg-1242
Hi Viyuan700 ..
thankyou .. :) this worked.
