Help in Setting up Cisco 2811 serial Leased Line connection.
andrewcsh
Hello to all,
I would like to mention that I am a total new comer (NOOB) for Cisco Router. All I know is plug the console cable to a serial port on a PC, fire-up HyperTerminal to view and that's it. I don't know any command or scripts.
I am trying to lend a hand to my client to help him setup his connection, I already receive the required configuration settings from ISP. It is a Leased Line Serial connection.
Could some of the gurus here teach me how to setup the router with the below configuration.
Serial IP : 1.X.XX.222
Serial Netmask : 255.255.255.XXX
LAN IP : 1.X.XXX.1 to 1.X.XXX.31
LAN Netmask : 255.255.255.XXX
Default gateway (IP Route) : 1.X.XX.221
Encapsulation : PPP
DNS Servers to point to : XXX.XXX.0.136 & XXX.XXX.1.5
(DQ) is 14602975 & 14602974
Thank you,
Andrew
5 Replies 5
Tod Larson
Level 3
Level 3
What sort of serial leased line?   T1?
Is the serial line an internet link or a link to another site on a private network?
Can you do a show run then cut paste the config you have into this thread?
Reza Sharifi
Hi Andrew,
You need to configure the IP address for each interface, but before you do that you need to figure out which LAN and WAN interfaces are in up and up mode.
So, once you login to the router issue this command to fiure out the interfaces":
"sh ip int bri" and post it here
also do a "sh run" and post the output here
johnlloyd_13
Level 9
Level 9
hi andrew,
could you post your show version output? how many serial links are you going to terminate on your 2811? i've noticed you've got 2 circuit IDs (DQ xxx).
Hi Guys,
Thanks for the prompt reply, Tod, John, for your information, it is a Internet Connection Direct over Leased Line, and yes, there are 2 serial links because its a 2Mbps x 2 connection into the 2811 router.
hi andrew,
thanks for confirming! kindly post your show version and show ip interface brief output.
as for the config on your 2811 obtain the /30 WAN IP address for the 2 serial links from your ISP and try to do as below:
ip name-server XXX.XXX.0.136
ip name-server XXX.XXX.1.5
interface serial x
description DQ 14602974
ip address a.a.a.a 255.255.255.252
encapsulation ppp
ppp multilink
multilink-group 1
interface serial y
description DQ 14602975
ip address b.b.b.b 255.255.255.252
encapsulation ppp
ppp multilink
multilink-group 1
interface multilink1
ip address 1.X.XX.222
ppp multilink
multilink-group 1
interface fast 0/0
ip address 1.X.XXX.1 255.255.255.XXX
ip route 0.0.0.0 0.0.0.0 1.X.XX.221
