Help in VDSL Dialing in Cisco 2901
yoadfekete
Hi Guys.
i've tried every possible configuration.
of course the line is all fine.
please let me know if you have any ideas why this configuration wouldn't connect?
#show run
Building configuration...
Current configuration : 2194 bytes
! Last configuration change at 11:39:09 UTC Wed Sep 19 2012
! NVRAM config last updated at 11:27:34 UTC Wed Sep 19 2012
version 15.1
service password-encryption
hostname ******
boot-start-marker
boot-end-marker
enable secret 5 **********************
enable password ************************
no aaa new-model
no ipv6 cef
ip source-route
ip routing
no ip cef
license udi pid CISCO2901/K9 sn FTX162986Y1
controller VDSL 0/0/0
interface Embedded-Service-Engine0/0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet0/0
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.0.60.199 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
interface ATM0/0/0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
no ip unreachables
ip route-cache flow
ip tcp adjust-mss 1452
shutdown
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ****** password 0 ****************
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
access-list 101 permit ip 10.0.60.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input ssh
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input ssh
scheduler allocate 20000 1000
end
6 Replies 6
cadet alain
no ip address
no ip unreachables
ip route-cache flow
shutdown
you should no shut the interface
Regards.
Alain
sorry - i look like a noob
i fixed that immediatley after uploading the question.
the reason it was shut is because i reseted the router to factory defaults to try and configure it from scratch.
i have enabled the interfaces (both ethernet and atm) and still nothing.
take a look here:
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/routconf.html#wp1219652
Regards.
Alain
Super thanks for that.
i have gone through that already.
i am getting an ip from ISP.
but seems like everything i'm trying to ping is not going through this connection.
if i'm pinging 8.8.8.8 all i get is
UUUUU
Did you keep your static default route pointing to dialer interface ?
--->sh ip route
If this is the case can you get rid of it( try your ping again) and  post you routing table content if it's still not working.
Regards.
Alain
tim.grantham
Are you trying to get this working with BT Inifinty in the UK?
If so, then you will need to tage the VLAN with ID 101
Set the Ethernet configuration as follows: -
description VDSL Infinity Connection
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no mop enabled
interface Ethernet0/0/0.101
encapsulation dot1Q 101
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
Also, configure the Dialer as follows: -
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname
ppp chap password
no cdp enable
