Help interpreting IOS ip packet debug detail results to help resolve VPN problem?
I am trying to diagnose a IPSec VPN issue.  I can extablish  VPN.  Packets seem to be arriving.  They are being decrypted but they are not exiting the router.
The setup uses an 1741w with 2 x ADSL router but for the purpose of my debug I have disabled one.  Wireless is also disabled.
ip CEF is off but I have also tried with CEF on.  The packet still does not exit thr router.
Wireshark is running on the target system (90.155.11.181) and is filtering for tcp port 80.  It is picking up requests from other IPs.
I am using IOS 15.3 and have a working zone based firewall.  I've established a site to site VPN using a crypto map as follows:
  class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
   match access-group 103
  policy-map type inspect ccp-permit-inservice
   class type inspect CCP_PPTP
    pass
   class type inspect sdm-cls-VPNOutsideToInside-1
    inspect
  class class-default
    drop log
  zone-pair security ccp-zp-out-in source out-zone destination in-zone
   service-policy type inspect ccp-permit-inservice
  access-list 101 remark CCP_ACL Category=4
  access-list 101 remark IPSec Rule
  access-list 101 permit ip 90.155.11.128 0.0.0.127 192.168.5.0 0.0.0.255
  access-list 103 remark CCP_ACL Category=0
  access-list 103 permit ip 192.168.5.0 0.0.0.255 90.155.11.128 0.0.0.127
  crypto isakmp policy 1
   encr 3des
   authentication pre-share
   group 2
  crypto isakmp key xxx address 0.0.0.0         no-xauth
  crypto dynamic-map SDM_DYNMAP_1 1
   set transform-set ESP-3DES-SHA1
   match address 101
  crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
  crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
   mode tunnel
  interface Dialer1
   description $FW_OUTSIDE$
   bandwidth 6000
   ip address negotiated
   ip flow ingress
   ip flow egress
   zone-member security out-zone
   encapsulation ppp
   dialer pool 2
   dialer-group 2
   ppp authentication chap pap callin
   ppp chap hostname xxx
   ppp chap password 0 xxx
   ppp pap sent-username xxx password 0 xxx
The packet trace looks like this:
2013-03-3015:24:14debug90.155.11.129local750864*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750863*Mar 30 15:24:25.285:     TCP src=62148, dst=80, seq=1866716499, ack=0, win=65535 SYN, CCE Post NAT Classification(40), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750862*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750861*Mar 30 15:24:25.285: IP: tableid=0, s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), routed via RIB
2013-03-3015:24:14debug90.155.11.129local750860, MCI Check(90), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750859*Mar 30 15:24:25.285:     TCP src=62148, dst=80, seq=1866716499, ack=0, win=65535 SYN
2013-03-3015:24:14debug90.155.11.129local750858*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750857*Mar 30 15:24:25.285:     TCP src=62148, dst=80, seq=1866716499, ack=0, win=65535 SYN, Virtual Fragment Reassembly After IPSec Decryption(49), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750856*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750855*Mar 30 15:24:25.285:     TCP src=62148, dst=80, seq=1866716499, ack=0, win=65535 SYN, Virtual Fragment Reassembly(33), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750854*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750853*Mar 30 15:24:25.285:     TCP src=62148, dst=80, seq=1866716499, ack=0, win=65535 SYN, Ingress-NetFlow(29), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750852*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750851*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, packet consumed, Firewall (firewall component)(42), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750850(GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750849*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181
2013-03-3015:24:14debug90.155.11.129local750848*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, CCE Post NAT Classification(40), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750847*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750846*Mar 30 15:24:25.285: IP: tableid=0, s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), routed via RIB
2013-03-3015:24:14debug90.155.11.129local750845*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, MCI Check(90), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750844*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750843*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, Virtual Fragment Reassembly After IPSec Decryption(49), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750842*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750841*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, Virtual Fragment Reassembly(33), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750840, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750839*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181
2013-03-3015:24:14debug90.155.11.129local750838*Mar 30 15:24:25.285:     TCP src=62149, dst=80, seq=1817213112, ack=0, win=65535 SYN, Ingress-NetFlow(29), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750837*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750836*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, packet consumed, Firewall (firewall component)(42), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750835*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750834*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, CCE Post NAT Classification(40), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750833*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), len 48, output feature
2013-03-3015:24:14debug90.155.11.129local750832*Mar 30 15:24:25.285: IP: tableid=0, s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181 (GigabitEthernet0/0), routed via RIB
2013-03-3015:24:14debug90.155.11.129local750831*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, MCI Check(90), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750830, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750829*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181
2013-03-3015:24:14debug90.155.11.129local750828*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, Virtual Fragment Reassembly After IPSec Decryption(49), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750827*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750826*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, Virtual Fragment Reassembly(33), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750825*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750824*Mar 30 15:24:25.285:     TCP src=62150, dst=80, seq=3741048627, ack=0, win=65535 SYN, Ingress-NetFlow(29), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
2013-03-3015:24:14debug90.155.11.129local750823*Mar 30 15:24:25.285: IP: s=192.168.5.254 (GigabitEthernet0/1), d=90.155.11.181, len 48, input feature
2013-03-3015:24:14debug90.155.11.129local750822*Mar 30 15:24:25.285: Punt packet to process switch
2013-03-3015:24:14debug90.155.11.129local750821*Mar 30 15:24:25.285: crypto_ceal_post_decrypt_switch: calling process switch
2013-03-3015:24:14debug90.155.11.129local750820*Mar 30 15:24:25.285: post_crypto_ip_decrypt: Data just decrypted, 48 bytes
2013-03-3015:24:14debug90.155.11.129local7508190E311420: 1F7E0000 020405B4 04020000           .~.....4....
2013-03-3015:24:14debug90.155.11.129local7508180E311410: F2C40050 6F43D553 00000000 7002FFFF  rD.PoCUS....p...
2013-03-3015:24:14debug90.155.11.129local7508170E311400: 5AA84000 3F06B429 C0A805FE 5A9B0BB5  Z(@.?.4)@(.~Z..5
2013-03-3015:24:14debug90.155.11.129local7508160E3113F0:                            45000030              E..0
2013-03-3015:24:14debug90.155.11.129local750815*Mar 30 15:24:25.281: After decryption:
2013-03-3015:24:14debug90.155.11.129local7508140E311400: 181A7FC8 9087856B                    ...H...k         ...
2013-03-3015:24:14debug90.155.11.129local7508130E3113F0: 00000025 23E8EB50 F31507F7 EDAC2AA9  ...%#hkPs..wm,*)
2013-03-3015:24:14debug90.155.11.129local7508120E3113E0: 3F3233E8 51BBFCF6 5A9B5E2F 3B3D2F31  ?23hQ;|vZ.^/;=/1
2013-03-3015:24:14debug90.155.11.129local7508110E3113D0:                   45000068 00004000          E..h..@.
2013-03-3015:24:14debug90.155.11.129local750810*Mar 30 15:24:25.281: Before decryption:
2013-03-3015:24:14debug90.155.11.129local750809*Mar 30 15:24:25.281: Punt packet to process switch
2013-03-3015:24:14debug90.155.11.129local750808*Mar 30 15:24:25.281: crypto_ceal_post_decrypt_switch: calling process switch
2013-03-3015:24:14debug90.155.11.129local750807*Mar 30 15:24:25.281: post_crypto_ip_decrypt: Data just decrypted, 48 bytes
2013-03-3015:24:14debug90.155.11.129local7508060D5A77A0: 7F0B0000 020405B4 04020000           .......4....
2013-03-3015:24:14debug90.155.11.129local7508050D5A7790: F2C50050 6C5078B8 00000000 7002FFFF  rE.PlPx8....p...
2013-03-3015:24:14debug90.155.11.129local7508040D5A7780: 888D4000 3F068644 C0A805FE 5A9B0BB5  ..@.?..D@(.~Z..5
2013-03-3015:24:14debug90.155.11.129local7508030D5A7770:                            45000030              E..0
2013-03-3015:24:14debug90.155.11.129local750802*Mar 30 15:24:25.281: After decryption:
2013-03-3015:24:14debug90.155.11.129local7508010D5A7780: 698DFA02 CD87BD21                    i.z.M.=!         ...
2013-03-3015:24:14debug90.155.11.129local7508000D5A7770: 00000024 839DC02B 9884796E 82DBC77A  ...$..@+..yn.[Gz
2013-03-3015:24:14debug90.155.11.129local7507990D5A7760: 3F3233E8 51BBFCF6 5A9B5E2F 3B3D2F31  ?23hQ;|vZ.^/;=/1
2013-03-3015:24:14debug90.155.11.129local7507980D5A7750:                   45000068 00004000          E..h..@.
2013-03-3015:24:14debug90.155.11.129local750797*Mar 30 15:24:25.281: Before decryption:
2013-03-3015:24:14debug90.155.11.129local750796*Mar 30 15:24:25.281: Punt packet to process switch
2013-03-3015:24:14debug90.155.11.129local750795*Mar 30 15:24:25.281: crypto_ceal_post_decrypt_switch: calling process switch
2013-03-3015:24:14debug90.155.11.129local750794*Mar 30 15:24:25.281: post_crypto_ip_decrypt: Data just decrypted, 48 bytes
2013-03-3015:24:14debug90.155.11.129local7507930E317420: A5E30000 020405B4 04020000           %c.....4....
2013-03-3015:24:14debug90.155.11.129local7507920E317410: F2C60050 DEFBDF33 00000000 7002FFFF  rF.P^{_3....p...
2013-03-3015:24:14debug90.155.11.129local7507910E317400: C6D64000 3F0647FB C0A805FE 5A9B0BB5  FV@.?.G{@(.~Z..5
2013-03-3015:24:14debug90.155.11.129local7507900E3173F0:                            45000030              E..0
2013-03-3015:24:14debug90.155.11.129local750789*Mar 30 15:24:25.281: After decryption:
2013-03-3015:24:14debug90.155.11.129local7507880E317400: EB77106D C78EA197                    kw.mG.!.         ...
2013-03-3015:24:14debug90.155.11.129local7507870E3173F0: 00000023 B33F5C0D 00F29B2B 394EF8D6  ...#3?\..r.+9NxV
2013-03-3015:24:14debug90.155.11.129local7507860E3173E0: 3F3233E8 51BBFCF6 5A9B5E2F 3B3D2F31  ?23hQ;|vZ.^/;=/1
2013-03-3015:24:14debug90.155.11.129local7507850E3173D0:                   45000068 00004000          E..h..@.
2013-03-3015:24:14debug90.155.11.129local750784*Mar 30 15:24:25.281: Before decryption:
At 50784 the packet enters and is being decrypted.
At 50822 - The packet is 'punted' to process switch
From then on the packet seems in transiit up to 'output feature'
Can anyone here tell what's happening to the packet.  The router seem to know that the destination address (90155.11.181) is on GigabitEthernet0/0 but the packet never arrives.  Wireshark never regesteres the request so as far as I can see the packet is not exiting the router.
Can anyone help interpret the packet debug?  Can anyone tell where the packet is going?
Chris
0 Replies 0
