Help (IPV6 subnetting)
demmahom619
Your Internet Service Provider sells you the IPv6 network of 2001:1111:2222::/48. Your company has a total of one hundred (100) broadcast domains so you decide to divide this network into IPv6 subnets using the technique of same-length subnet masking.
Your plan is to start with Subnet-Zero as your first subnet, and to have as few networking bits as possible per subnet so you can maximize your quantity of hosts-per-subnet.
Given above-mentioned design, which of the IPv6 networks below represents the twenty-eighth (28th) IPv6 subnet?
Peter Paluch
Looks like some test question :)
Either way, for 100 networks, you need to borrow additional 7 bits, extending the prefix length from /48 to /48+7 = /55. This will actually create 128 new subnets, out of which 28 won't be utilized momentarily.
Now, let's see what happens with this extended prefix. The 2001:1111:2222 part is already 48 bits long and it cannot be changed. From the next 2-byte field "after" the 2222, we will consume additional 7 bits, so it will be, written out in bits:
SSSS SSSH HHHH HHHH
where 'S' stands for a subnet bit, and 'H' stands for a host bit. The red 'S' bits are the ones we have borrowed into the subnet part, and whenever they change, they create a new subnet. So the actual combinations are, with the host bits zeroed out (since not relevant for an address prefix):
0000 0000 0000 0000 = 0x0000 => 2001:1111:2222:0000::/55 (1st)
0000 001
0 0000 0000 = 0x0200 => 2001:1111:2222:0200::/55 (2nd)
0000 010
0 0000 0000 = 0x0400 => 2001:1111:2222:0400::/55 (3rd)
0000 011
0 0000 0000 = 0x0600 => 2001:1111:2222:0600::/55 (4th)
0000 100
0 0000 0000 = 0x0800 => 2001:1111:2222:0800::/55 (5th)
... and so on.
Note that the because we "mask out" the lowest bit in the 7th byte of the IPv6 address (that is the one with the red S bits), each next subnet comes in a multiple of 2 in the value of this byte. Since all zeros is the first subnet, the 28th subnet is 27x2 = 54 = 0x36, so 2001:1111:2222:3600::/55.
Do note, however, that this kind of subnetting is possible but not used with IPv6. Typically, you would just extend the prefix length from /48 to /64, yielding 65536 possible subnets, each one of them still large beyond imagination (2^64 hosts, which is 4.2 billion times larger than the whole IPv4 internet), and the numbering would be much simpler:
2001:1111:2222:0000::/64 for the 1st subnet
2001:1111:2222:0001::/64 for the 2nd subnet
2001:1111:2222:0002::/64 for the 3rd subnet
2001:1111:2222:001b::/64 for the 28th subnet (0x1b = 27 since we're numbering from 0)
Also, the IPv6 addressing architecture requires that the host part is 64 bits long; using a prefix length of /55 would violate this requirement.
Feel welcome to ask further!
Best regards,
Peter
Peter Paluch
SSSS SSSH HHHH HHHH
0000 001
0000 010
0000 011
0000 100
... and so on.
Best regards,
Peter
Thank you so much, that was helpful
