CEF Load Balancing
arkardaniels
I would like to setup CEF Per-Destination Load Balancing and could anyone explain to me that the steps I'm taking are going towards the right direction please?
CEF is enabled by default.
Received ip address from 2x Edge soho routers on 2x FastEthernet (0-1) WAN links.
Both 192.168.x.x /24 different Subnets.
Created Access-List 10  to allow 10.x.x.x /24 LAN Subnet on FastEthernet(2)
2x ip nat outside on WAN, ip nat inside on LAN
route-map One permit 20
match ip address 10
match interface FastEthernet1/0
route-map Two permit 20
match ip address 10
match interface FastEthernet1/1
ip nat inside source route-map One interface FastEthernet1/0 overload
ip nat inside source route-map Two interface FastEthernet1/1 overload
Result
All nodes from Subnet 10.x.x.x /24 LAN can go online.
ip nat translation shows it's working properly.
BUT I can not ping to internet from LAN default-router address (Fa1/2) and sometime I can.
I really would like to know why.
kind regards,
AD
Hello
Given you current setup you may need to apply some additional configuration to get this to work as you have requested?
For LB per destination, well it does that by default  you should be able to see that with this command, if you continually apply it you see the cef path it will take
sh ip cef exact-route 10.0.0.150 8.8.8.8
Now given you have dhcp enabled wan links your two default static routes I don't think will be able to have any sla tracking applied them so you would need a way to conditional route and nat between the two wan links.
Embedded event manager ( EEM) should be able assist here?
ip route 0.0.0.0 0.0.0.0 VLAN3 dhcp
ip route 0.0.0.0 0.0.0.0 VLAN7 dhcp 250
event manager applet VLAN3-DOWN
 event track 1 state down
 action 5.0 cli command "enable"
 action 5.1 cli command "conf t"
 action 5.2 cli command "no ip route 0.0.0.0 0.0.0.0 VLAN3 dhcp"
 action 5.3 cli command "exit"
 action 5.4 cli command "clear ip nat translation *"
 action 5.5 cli command "end"
event manager applet VLAN3-UP
 event track 1 state up
 action 5.5 cli command "enable"
 action 5.6 cli command "conf t"
 action 5.7 cli command "ip route 0.0.0.0 0.0.0.0 VLAN3 dhcp"
 action 5.8 cli command "exit"
 action 5.9 cli command "clear ip nat translation *"
 action 6.0 cli command "end"
ip sla 10
icmp-echo X.X.X.X source-interface VLAN3
frequency 5
ip sla schedule 10 life forever start-time now
track 1 rtr 10
sh ip route
sh ip nat translations
sh track
Try the above configuration and test again
res
Paul
Kind Regards
Paul
which routes do you have installed ? Post the full config of your router...
Thanks so much for reply mate.
Cisco 887VA-W
version 15.6
hostname example
boot-start-marker
boot-end-marker
enable secret 5 $1$8M.G$JoDaY8Fx5frE/.LSaWVxb.
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 10.0.0.1 10.0.0.160
ip dhcp excluded-address 10.0.0.191 10.0.0.254
ip dhcp pool local-pool
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.150
 dns-server 208.67.222.222
 lease 7
ip domain name example.home
ip cef
no ipv6 cef
username Bob privilege 15 secret 5 $1$dtjq$TMFkDEnBhitoMTLmvF2eN0
controller VDSL 0
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
 shutdown
interface FastEthernet0
 switchport access vlan 3
 no ip address
 switchport access vlan 7
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Wlan-GigabitEthernet0
 no ip address
interface wlan-ap0
 no ip address
interface Vlan1
 ip address 10.0.0.150 255.255.255.0
 ip access-group DNS-Blocker in
 ip nat inside
 ip virtual-reassembly in
interface Vlan3
 ip address dhcp
 ip nat outside
interface Vlan7
 ip address dhcp
 ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map Conn-1 interface Vlan3 overload
ip nat inside source route-map Conn-2 interface Vlan7 overload
ip ssh version 2
ip access-list extended DNS-Blocker
 permit udp 10.0.0.0 0.0.0.255 host 208.67.222.222 eq domain
 permit tcp 10.0.0.0 0.0.0.255 host 208.67.222.222 eq domain
 deny   udp any any eq domain
 deny   tcp any any eq domain
 permit ip any any
route-map Conn-1 permit 10
 match ip address 10
 match interface Vlan3
route-map Conn-2 permit 10
 match ip address 10
 match interface Vlan7
access-list 10 permit 10.0.0.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no vstack
line con 0
 logging synchronous
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line vty 0 4
 exec-timeout 5 0
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
try and add the below to your configuration:
ip route 0.0.0.0 0.0.0.0 vlan3 dhcp
ip route 0.0.0.0 0.0.0.0 vlan7 dhcp
Hello
ip sla 10
frequency 5
track 1 rtr 10
sh ip route
sh track
res
Paul
Kind Regards
Paul
