Help me to find the required Wireless access point
ShekibRasheedi
Dear Friends,
I am in search of a access point with below specification, so please let me know that which model has this functionalities.
. Wireless Access Point:
* No of port should be 10Base-T/100Base-TX Ethernet
* Standard should be IEEE 802.11g, IEEE802.11b, IEEE 802.3, IEEE 802.3u, IEEE 802.3af(PoE), 802.1q(VLAN) , 802.1X(Security authentication), 802.11i ready (Security WPA2), 802.11e ready (wireless QoS), 802.11F(Wireless roaming)
* LEDs should be power, PoE, Wireless, Ethernet
* Web Management should be built-in web user interface for easy browser-based configuration (HTTP/HTTPS)
* SNMP Support should be SNMP version 1, 2c, 3
* Operation modes should be access point made, point to point bridge mode, point to point multipoint bridge mode, repeater mode
* External antennas should be 2 (omni directional) SMA detachable
* Security should be WEP 64-bit/128-bit, WPA-PSK, WPA2-PSK, WPA-ENT, WPA2-ENT
* Access Control should be wireless connection control: MAC-based
* Wireless Security monitor should be Intrusion alarms(e.g. rogue client detected, spoofed MAC address) Denial-of-service alarms (e.g. duration attack, association table full) vulnerability alarms (e.g. access point is not using encryption, access point is broadcasting SSID)
* Power should be 12V 1A DC input, and IEEE 802.3af compliant PoE. Maximum power draw should be 3.36W
I would highly appreciate your fast respons.
thanks for your help in very advance.
Thanks and regards,
Shekib
Phillip Remaker
Are any of these points negotiable? These requirements seem odd and outdated.
The WAP4410N comes close
http://www.google.com/products/catalog?q=Linksys+POE+access+point&oe=utf-8&client=firefox-a&rlz=1R1GGLL_en&um=1&ie=UTF-8&cid=7902726625175455904&ei=uDDVTJPDA4a0sAP8p4mNCw&sa=X&oi=product_catalog_result&ct=result&resnum=1&ved=0CCUQ8wIwAA&os=tech-specs
But you would really want a managed Wireless Lan controller to get the solid roaming and rogue detection.
A better choice would be one of Cisco's Enterprise-class access points are at http://www.cisco.com/en/US/products/hw/wireless/index.html#N67BB91
But the newer ones are MIMO and 802.11n based - every modern access point should have more than two antennas.   I'm surprised you are not looking for dual band.
You might also look more carefully at your requirements - For example, 802.11F was withdrawn in 2006, no vendor should be supporting it.
