Can 880s router support daul WAN?
a3948692
we are considering this model: CISCO887GW-GN-A-K9
but we are not very sure if it support dual wan (use both wan connections in the same time).
details: we are intend to use the router to connect vpn back to HQ.  remote sites have some application/system and many server in HQ.
so we want to deliver deferent connection to deferent WAN port and the 2 WAN port can backup each other.
I saw on cisco.com it can establish "concurrent connection" but someone told me 880s can only use 3G as a backup "uplink".
thanks for reading.
paolo bevilacqua
On cisco routers, all interfaces can be used simultaneously for any possible purpose.
This include the 880 series.
5 Replies 5
paolo bevilacqua
so, I think I establish 2 VPN to HQ, and route or nat traffices base on ports? e.g. port 80 / 21 goes to int 0 and all else goes to int 1.
thanks.
PBR would accomplish your requirement.
Thanks for the nice rating and good luck!
thanks, is "PBR" = Performance Routing or something else?
Policy Based Routing.
I recommend you engage a reputable consultant or certified cisco partner for all aspects of network and configuration.
