Help - Need to change Next-Hop to default route in BGP
moorepl
Hi All
I'm trying to figure out if I can change the next-hop to a default route that I am injecting into BGP. I have basically configured a WAN network connecting 4 routers (as below) with eBGP and iBGP peers. The WAN links are reachable via eigrp, and the BGP peering takes place to L0's which are also reachable via eigrp. I want R2 to send the route to the downstream DEG router, but I want the next-hop not to be the source L0, but a firewall interface. So all  traffic destined for the default route will be sent to the firewall. In the event the upstream router goes offline, another default-route should be seen via iBGP, it too will need it's next-hop attribute changed to another firewall ip address. See the diagram below and config for routers.
The servers downstream are vlans 10, 11, 20 (On left) and vlan 30 on right with network IPs 10.10.10.10, 11.11.11.10, 20.20.20.10 and 30.30.30.10 respectively. Their default gateway is currently the L3 SVI on the MSFC. I want the default route that comes from R2 on the right to DEG on the bottom right, to have the next hop of the local inside firewall 10.
Router 2 Config
R2#sho run
Building configuration...
Current configuration : 1535 bytes
! Last configuration change at 00:35:27 UTC Fri Jun 6 2014
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
interface Loopback0
 description BGP Neigh Adjacency
 ip address 4.4.4.4 255.255.255.255
interface FastEthernet0/0
 no ip address
 shutdown
 duplex full
interface GigabitEthernet1/0
 no ip address
 shutdown
 negotiation auto
interface FastEthernet2/0
 description P2P Link P2P Link for BGP Remote_AS 65501
 ip address 192.168.200.4 255.255.255.0
 speed auto
 duplex auto
interface FastEthernet2/1
 no ip address
 shutdown
 speed auto
 duplex auto
router eigrp 100
 network 4.0.0.0
 network 192.168.200.0
router bgp 605
 bgp log-neighbor-changes
 neighbor 2.2.2.2 remote-as 605
 neighbor 3.3.3.3 remote-as 65501
 neighbor 3.3.3.3 ebgp-multihop 10
 neighbor 3.3.3.3 update-source Loopback0
 neighbor 3.3.3.3 default-originate route-map DEG_Def_Route
ip forward-protocol nd
no ip http server
no ip http secure-server
route-map DEG_Def_Route permit 10
 set ip next-hop 10.108.129.10
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
DEG N7k Router
DEG_Core-N7000-SW#sho run
Current configuration : 3864 bytes
version 12.4
no service dhcp
hostname DEG_Core-N7000-SW
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp file nvram:vlan.dat
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
 description P2P Link for BGP Remote_AS 605
 ip address 192.168.200.3 255.255.255.0
 speed 100
 full-duplex
interface FastEthernet0/1
 description *** Unused for Layer2 SW ***
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet1/0
 switchport access vlan 30
 duplex full
 speed 100
interface FastEthernet1/1
 duplex full
 speed 100
output omitted
interface FastEthernet1/11
 duplex full
 speed 100
interface FastEthernet1/12
 duplex full
 speed 100
interface FastEthernet1/13
 description L3 Link for iBGP
 no switchport
 ip address 192.168.201.2 255.255.255.252
 duplex full
 speed 100
interface FastEthernet1/14
 duplex full
 speed 100
interface FastEthernet1/15
 description Layer 2 Link to CW N7K
 switchport mode trunk
 duplex full
 speed 100
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description Finance Dept Vlan
 ip address 10.10.10.2 255.255.255.0
 standby 10 ip 10.10.10.3
interface Vlan11
 description Sales Dept Vlan
 ip address 11.11.11.2 255.255.255.0
 standby 11 ip 11.11.11.3
 standby 11 priority 200
 standby 11 preempt
interface Vlan30
 description DEG Local
 ip address 30.30.30.1 255.255.255.0
router eigrp 100
 network 3.0.0.0
 network 192.168.201.0
 no auto-summary
router bgp 65501
 no synchronization
 network 10.10.10.0 mask 255.255.255.0
 network 11.11.11.0 mask 255.255.255.0
 network 20.20.20.0 mask 255.255.255.0
 network 30.30.30.0 mask 255.255.255.0
 neighbor 1.1.1.1 remote-as 65501
 neighbor 1.1.1.1 update-source Loopback0
 neighbor 4.4.4.4 remote-as 605
 neighbor 4.4.4.4 ebgp-multihop 10
 neighbor 4.4.4.4 update-source Loopback0
 no auto-summary
no ip http server
access-list 100 permit ip any host 1.1.1.1
access-list 110 permit ip any host 2.2.2.2
route-map Secondary_to_R4 permit 10
 match ip address 110
 set ip next-hop 10.104.128.10
route-map Primary_to_R2 permit 10
 match ip address 100
 set ip next-hop 10.104.129.10
control-plane
banner exec ^C
This is a normal Router with a SW module inside (NM-16ESW)
It has been preconfigured with hard-code speed and duplex
To create vlans use the command "vlan database" from exec mode
After creating all desired vlans use "exit" to apply the config
To view existing vlans use the command "show vlan-switch brief"
Warning: You are using an old IOS image for this router.
Please update the IOS to enable the "macro" command!
^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
DEG_Core-N7000-SW#
R4 Router Config
R4#sho run
Current configuration : 1465 bytes
! Last configuration change at 21:22:34 UTC Thu Jun 5 2014
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
interface Loopback0
 description BGB Neigh Adjacency
 ip address 2.2.2.2 255.255.255.255
 no ip address
 shutdown
 duplex full
 no ip address
 shutdown
 negotiation auto
 description P2P Link for BGB Rmote_AS 65501
 ip address 192.168.200.2 255.255.255.0
 speed auto
 duplex auto
 no ip address
 shutdown
 speed auto
 duplex auto
router eigrp 100
 network 2.0.0.0
router bgp 605
 neighbor 1.1.1.1 ebgp-multihop 10
 neighbor 1.1.1.1 default-originate
 default-information originate
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R4#
CW N7K Router Config
CW_Core-N7000-SW#sho run
Current configuration : 3731 bytes
version 12.4
no service dhcp
hostname CW_Core-N7000-SW
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 ip address 192.168.200.1 255.255.255.0
 speed 100
 full-duplex
 no ip address
 duplex auto
 speed auto
 switchport access vlan 10
 duplex full
 speed 100
 description Link to Sales Server
 switchport access vlan 11
 duplex full
 speed 100
interface FastEthernet1/2
 switchport access vlan 20
 duplex full
 speed 100
 no switchport
 ip address 192.168.201.1 255.255.255.252
 duplex full
 speed 100
 no switchport
 no ip address
 duplex full
 speed 100
 description Layer 2 Link to DEG N7K
 duplex full
 speed 100
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.10.10.1 255.255.255.0
 standby 10 priority 200
 standby 10 preempt
interface Vlan11
 ip address 11.11.11.1 255.255.255.0
interface Vlan20
 description CityWest Local
 ip address 20.20.20.1 255.255.255.0
router eigrp 100
 network 1.0.0.0
 no auto-summary
router bgp 65501
 no synchronization
 neighbor 2.2.2.2 ebgp-multihop 10
 neighbor 2.2.2.2 update-source Loopback0
 no auto-summary
no ip http server
control-plane
^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
CW_Core-N7000-SW#
Thanks in advance for any and all help guys.... I appreciate it.
Mooey
moorepl
Topology Diagram
