Help needed for default route for new vlan
91da49851
Hello all
I have a Cisco Firepower 1010 running ASA. I would like one of the physical ports Ethernet1/6 to be separated from other the other ports on my inside but it should have access to the internet. I will connect my Hikvision video monitoring and Huawei solar panel inverters to this port. I have created a vlan for this named HikvisionHuawei and set up DHCP and DNS for this. When I connect my laptop to port 6 I get assigned an ip address as expected, but I can not reach or ping any address. I get the error message
no route to host
I have tried defining a default route using the
route command
but I keep getting error messages when I try to use the
route command
route HikvisionHuawei 0 0 192.168.1.1
ERROR: Invalid next hop address 192.168.1.1, it matches our IP address
route HikvisionHuawei 0 0 212.130.193.38
ERROR: Invalid next hop address 212.130.193.38, it matches our IP address
I have attached a file with my configuration and various other
show commands
Please let me know what I'm missing in my setup.
22 Replies 22
it should stop after Phase 8, instead it goes to Phase 9 and finds the static default route. Can you try a
clear route all
, and if that does not help
wr mem
the config and reboot the ASA ?
Hi again
I tried the
clear route all
but got the same result: not able to connect.
I ran the
write mem
and restarted the appliance completely and then I tried connecting again. Still the same.
I'm sorry for having such a hard issue here.
packet-tracer input inside icmp 192.168.20.20 8 0 192.168.1.1
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 192.168.1.1 using egress ifc identity
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Phase: 3
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: CLUSTER-REDIRECT
Subtype: cluster-redirect
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 4559, packet dispatched to next module
Phase: 9
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
found next-hop 0.0.0.0 using egress ifc identity
Phase: 10
Type: ADJACENCY-LOOKUP
Subtype: next-hop and adjacency
Result: ALLOW
Config:
adjacency Active
next-hop mac address 0000.0000.0000 hits 170 reference 2
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
Action: allow
friend I run lab I will finish it tomorrow, I will update you.
Thank you very much.
I'm looking forward to hearing from you after testing in lab.
I think as of now you have tried all 'options'.
What if you remove this NAT statement (which is redundant anyway) ?
nat (HikvisionHuawei,outside) after-auto source dynamic any interface
Good suggestion. I ran
no nat (HikvisionHuawei,outside) after-auto source dynamic any interface
But still, not able to connect.
BTW Today, I installed the Cisco Packet Tracer app, and hoped that I could set up my network there. Unfortunately, it does not have any Firepower components in the toolbox.
I have solved it by adding an object. This is the commands I needed to add:
object network IOT
subnet 192.168.20.0 255.255.255.0
description IOT-NETWORK
nat (HikvisionHuawei,outside) dynamic interface
exit
interface vlan20
security-level 20
write mem
And it worked!!!!
I get the right IP address 192.168.20.100 when I connect and I can ping and connect to the internet, and not connect to any other network objects on my 'inside'.
Thanks Georg and MHN for your inspiration and time. I really appreciate your effort.
You are so so welcome
