help on how to upgrade cisco 1801 ios v12.4 to 15.1
malai.joseph
hello
Kindly help on how to upgrde cisco 1801 ios version  12.4 to 15.1 step by step
thx
joseph
mfurnival
Level 4
Level 4
IOS install procedure is covered here:
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/49044-sw-upgrade-proc-ram.html
Some things to watch out for:
- make sure you have enough space on your flash for both old and new IOS then you can roll back if need be
- 15 IOS functionality is controlled by licensing whereas 12.4 is not so be aware that you may have to pay for certain features.
mfurnival
Level 4
Level 4
Hello mfurnival,
Thanks for quick respond
How to take backup of  IOS image from v15.1 cisco and overwrite to 12.4 v
Joseph
