Help - Router 857
RubinoM
With this model I can't use the ADSL connection because the atm interface don't change your state to up.
With debug atm events output is:
*Mar 3 05:26:01.117: DSL: Send ADSL_OPEN command.
*Mar 3 05:26:01.117: DSL(ATM0): Using subfunction 0x0
*Mar 3 05:26:01.117: LOCAL:Max noise margin for power cutoff 31
*Mar 3 05:26:01.117: DSL(ATM0): Sent command 0x3
*Mar 3 05:26:03.617: DSL(ATM0): 1: Modem state = 0x9
*Mar 3 05:26:06.117: DSL(ATM0): 2: Modem state = 0x10
*Mar 3 05:26:08.617: DSL(ATM0): 3: Modem state = 0x10
*Mar 3 05:26:11.117: DSL(ATM0): 4: Modem state = 0x10
*Mar 3 05:26:13.617: DSL(ATM0): 5: Modem state = 0x10
*Mar 3 05:26:15.577: DSL: Received response: 0x22
*Mar 3 05:26:15.577: DSL: Open failed: Error in early non-CRC message or in fir
st CRC-covered message -- retrying
*Mar 3 05:26:15.577: sleep 5 seconds
The configuration is:
Current configuration : 2618 bytes
version 12.3
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username xxxx secret xxxx
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ftp-server write-enable
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip nat outside
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
ip address 172.16.10.102 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 100 interface ATM0.1 overload
access-list 100 permit ip 172.16.10.0 0.0.0.255 any
no cdp run
line con 0
login local
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
spremkumar
Level 9
Level 9
spremkumar
Level 9
Level 9
hi
can you refer this link link and check whether you are able to make it up after changing the dsl operating mode and also the PVC ??
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dda6682
regds
