Help to build a network 69 for students.
Jhon Taker
Dear people,
In this discussion il add some cli for fellow employees which wil also ad some commands.
My first one is
Vlan-database maken:
(IP routing moet aan staan)
Vlan 10
Name Balie
Exit
Int vlan 10
Ip address 172.16.10.1 255.255.255.0
Exit
Do wr
Hopefully someone can use this
9 Replies 9
Bob420
heyy i saw you post and i have some info hope ist helpfull
VTP configuration:
VTP domain Singularity.nl
VTP mode Server of Client
Trunkpoorten aan maken:
INT Gig0/1
(switchport trunk encapsulation [dot1q | isl] )
Switchport mode trunk
Switchport trunk allowed vlan all
Exit
Do wr
Int range Fa0/1-10
Exit
Do wr
Jhon Taker
I to found some we could use. il post them beneath here.
Let me know if it was helpfull.
Spanning-Tree:
Spanning-Tree vlan 1-1000 Root
Spannig-Tree priority (8192-4096)
Exit
Poortindeling (access vlan):
Int gig 0/1 (de poort hang van het schema af)
Switchport mode access
Switchport access vlan 10
DHCP pools aanmaken:
IP dhcp pool Balie
Network 172.16.10.0 255.255.255.0
Default router 172.16.10.1
DNS server 180.115.0.6
Exit
Do wr
Hey man look at thiss my friend sended me:
IP dhcp pool Balie
Exit
Do wr
Access control list:
Access-list 101 deny ip 172.16.60.0 0.0.0.255 172.16.10.0 0.0.0.255
Access-list 101 deny ip 172.16.60.0 0.0.0.255 172.16.20.0 0.0.0.255
Access-list 101 permit ip any any
Int vlan 60
Ip access-group 101 in
Jhon Taker
I to got some code from a developer friend from my company.
These lines of code are very importend to use.
Concetie maken tussen de router en de switch:
Int gig1/1/1
No switchport
Ip address 172.16.0.2 255.255.255.0 (switch)
Ip address 172.16.0.1 255.255.255.0 (router)
OSPF:
Router OSPF:
Router ospf 1
Log-adjacency-changes
Network 172.16.0.0 0.0.255.255 area 0
Default-information originate
Exit
Do wr
Switch OSPF:
Exit
Do wr
Wan config:
Via isp moet met dhcp
Int gig0/0
Ip add dhcp
Yes so this is reaaaallly helpfull
Wan config:
Int gig0/0
Ip add dhcp
NAT:
Int gig 0/0
Ip nat outside
Gig 0/1
Ip nat inside
(ip nat inside source list 1 int gog 0/0 overload access-list 1 permit any)
Jhon Taker
I have some SSh code wich can be used to make the network safer.
it goes like the following.
SSH:
Er moet een domain name zijn
IP domain-name Beheer_Singularity.nl
crypto key generate rsa (1024 bits)
IP ssh version 2
line vty 0 4
transport input ssh
login local
username xxx password xxx
Jhon Taker
And before i forget to test SSH you need to use the command.
SSH -l user-name Ip-switch
Bob420
lldp neighbors multi layer switch or other switches
ssh -ladmin <ipadress from where you like to connect to (other switches)>
show start up config / copy running config
TFTP service / CLI show interface status\
cmd ping to other vlans NTP service server / show clock show port-security
other configs:
Vlan 10
Name Balie
Exit
Int vlan 10
Exit
Do wr
VTP configuration:
INT Gig0/1
Exit
Do wr
Int range Fa0/1-10
Exit
Do wr
Spanning-Tree:
Exit
IP dhcp pool Balie
Exit
Do wr
Int vlan 60
Int gig1/1/1
No switchport
OSPF:
Router OSPF:
Router ospf 1
Exit
Do wr
Switch OSPF:
Exit
Do wr
Wan config:
Int gig0/0
Ip add dhcp
NAT:
Int gig 0/0
Ip nat outside
Gig 0/1
Ip nat inside
SSH:
IP ssh version 2
line vty 0 4
transport input ssh
login local
 <peeps in the stuff>
Bob420
