Help to configure a https client
Steph1963
I am trying to copy a file from an https server. The https server has the following configuration:
ip domain name test
aaa authentication login HTTPS local
aaa authorization exec HTTPS local
username USER privilege 15 password 0 CISCO
ip http authentication aaa login-authentication HTTPS
ip http authentication aaa exec-authorization HTTPS
ip http secure-server
ip http path disk0:
Note: I have also generate a 1024 bit rsa key with "cryppto key generate rsa"
I can copy a file from my R2 server using http:
R1#copy http://USER:CISCO@10.0.0.2/disk0:running-config disk0:nulltest
Destination filename [nulltest]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
Loading http://**********@10.0.0.2/disk0:running-config !
The problem is that I keep having the same error message when I am trying to copy a file from the server on my R1 router:
R1#copy https://USER:CISCO@10.0.0.2/disk0:running-config disk0:nulltest
%Error opening https://USER:CISCO@10.0.0.2/disk0:running-config (I/O error)
R1#
*Apr 30 21:56:34.063: %HTTPS: http ssl get context fail (-41104)
*Apr 30 21:56:34.063: HTTP: ssl get context failed (-40407)
Note: I could not find any information on the meaning of these two errors.
Any help would be greatly appreciated
Stephane
0 Replies 0
