2811 using sub-interfaces and PPPOE on ADSL
chrismic1995
Hello everybody, I am trying to get my Cisco 2811 to authenticate four DSL connections and load balance them by attaching the four DSL to a switch (each DSL going to a seperate VLAN) and then trunking all four VLAN's to a ethernet interface on the 2811.  My issue, I can not get more than one DSL to authenticate at a time, for example Dialer1 will connect and then it will disconnect and Dialer2 will connect, etc...  I have the modems in bridge mode and I am using seperate user/pass for each DSL account and I have verified that the user/pass are correct.
Below is my config from the router and a couple of messages that came across the console.
Can I even do what I am trying to accomplish?
Chris
*Apr 27 01:12:11.915: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Apr 27 01:12:11.927: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Apr 27 01:12:11.931: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Apr 27 01:12:14.083: %DIALER-6-BIND: Interface Vi2 bound to profile Di2
*Apr 27 01:12:14.087: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Apr 27 01:12:14.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
*Apr 27 01:12:32.139: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di2
*Apr 27 01:12:32.147: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Apr 27 01:12:32.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Apr 27 01:12:34.299: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Apr 27 01:12:34.307: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Apr 27 01:12:34.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Router#show run
Building configuration...
Current configuration : 3648 bytes
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.20.1.1
ip dhcp pool client
network 172.20.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 172.20.1.1
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1041A1B5
username test privilege 15 secret 4 554Nq1aum3M01wRZ6FSR6rROZ6s/k8xo9EBYady0t6o
interface FastEthernet0/0
description LAN
ip address 172.20.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.11
encapsulation dot1Q 11
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1.12
encapsulation dot1Q 12
pppoe-client dial-pool-number 2
interface FastEthernet0/1.13
encapsulation dot1Q 13
pppoe-client dial-pool-number 3
interface FastEthernet0/1.14
encapsulation dot1Q 14
pppoe-client dial-pool-number 4
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname XXXX
ppp chap password 0 XXXX
ppp pap sent-username XXXX password 0 XXXX
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
interface Dialer3
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 3
interface Dialer4
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 4
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map DIAL1 interface Dialer1 overload
ip nat inside source route-map DIAL2 interface Dialer2 overload
ip nat inside source route-map DIAL3 interface Dialer3 overload
ip nat inside source route-map DIAL4 interface Dialer4 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer3
ip route 0.0.0.0 0.0.0.0 Dialer4
access-list 1 permit 172.20.1.0 0.0.0.255
route-map DIAL1 permit 10
match ip address 1
match interface Dialer1
route-map DIAL2 permit 10
match ip address 1
match interface Dialer2
route-map DIAL3 permit 10
match ip address 1
match interface Dialer3
route-map DIAL4 permit 10
match ip address 1
match interface Dialer4
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Router#
7 Replies 7
paolo bevilacqua
Try updating IOS.
Paolo, does my config look correct?  Is it possible to authenticate 4 DSL's on subinterfaces?  Do you know what IOS works, I only have 256M or RAM, at this time I can not go to the lateset 15 IOS but I should be able to upgrade a couple small steps.
Report again when you have been able to update. You can easily add the needed memory.
chrismic1995
I was wrong about the IOS, I am at the latest for the 2811?  Anybody have any thougths on this, is it possible, is my config wrong?
Router#show version
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Technical Support: _http://www.cisco.com/techsupport
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 04:14 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Router uptime is 3 days, 23 hours, 41 minutes
System returned to ROM by reload at 00:15:02 UTC Sat Apr 27 2013
System image file is "flash:c2800nm-entservicesk9-mz.151-4.M6.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
_http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
export@cisco.com.
Cisco 2811 (revision 1.0) with 249856K/12288K bytes of memory.
Processor board ID
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router#
Router#
It is latest.
Try pppoe config on a separate physical interface. It can co-exist with IP address and the interface working normally.
Sorry, I am trying to follow...
Do you want me to swap my LAN physical interface with my WAN (PPPOE) sub interface?
I do not have enough physical interfaces to do two PPPOE sessions and have a LAN physical interface at the same time, or do you want me to get rid of my LAN interface and use both physical interfaces (as a test) as the PPPOE dialer?
Just an FYI I am able to get one PPPOE session to work correctly on a sub-interface, when it is the only dialer built in the config.
Thanks for you help Paolo....
CM
What I'm saying is that you can try putting pppoe on two physical interfaces and that should allow you to have multiple sessions. The if that works you would need a 2 FE card to host 4 pppoe interfaces.
One inerface wil be shared with internal LAN, so you will have to use a switch for that.
Another possibility that will bring better results, is to  use HWIC ADSL cards instead of external modems.
