Help understanding BGP confederations
gavin.mckee
I'm trying to understand BGP conferdations much better (the Cisco BGP case studies does not answer all my questions). The attached diagram and configs are froma lab I set up to try and understand how a confederation works. My problem is that router 4 has an EBGP session to R5, these routes are then passed on via an iBGP peering to R3, however R3 does not pass these onwards to R1. If I try to mesh the sessions i.e iBGP via confederation to R1 the session will not come active, trying to peer to both the loopback and the physical interfaces will not work.. Its like the router thinks its an EBGP connection without EBGP multihop configured. I did try to put neighbour 1.1.1.1 ebgp-multihop 5 in and the sessions will still not come up.
Can anyone help with my understanding or lack of?
Gavin
Help well rated
tcordier
I assume that the BGP peering between R4 and R5, as well as between R4 and R3 are working fine, and only your peering between R3 and R1 is not coming up. I also assume that you can ping R1 10.1.13.1 from R3, and v.v?
The BGP configuration on R3 should be something like:
router bgp 70
bgp-confederation-id 5500
bgp-confederation peers 60
neighbor 10.1.13.1 remote-as 60
and on R1:
router bgp 60
bgp-confederation peers 70
neighbor 10.1.13.2 remote-as 70
Are the assumptions correct, and is your config about the same (I only included the configuration for R3 and R1 peering, not any other peering)?
- Thomas
Giuseppe Larosa
Hello Gavin,
first of all BGP sessions between different mini ASes like 60 and 70 in your example are treated in part as iBGP and in part as eBGP sessions.
In order to setup an eBGP session between R1 and R3 using loopbacks you will need:
R3
router bgp 70
neigh 1.1.1.1 remote-as 60
neigh 1.1.1.1 ebgp-multihop 2
neigh 1.1.1.1 update-source loop3
on R1
router bgp 60
neigh 3.3.3.3 remote-as 70
neigh 3.3.3.3 ebgp-multihop 2
neigh 3.3.3.3 update-source loop1
this should come up because all the routers are in IGP OSPF area 0.
Second Note:
to verify if a BGP session is up use
sh ip bgp summary and check the state and if established the number of prefixes received.
In fact, real eBGP routes have AD 20 and are preferred to OSPF (AD 110), pure iBGP routes have AD 200 and are ignored in comparison with OSPF routes.
What is the AD of confederation eBGP routes ?
20 I have seen I checked in my own test
However, I suggest to verify with
sh ip bgp prefix
and
sh ip route prefix
Third Note:
R3 is redistributing OSPF 100 into BGP.
In a initial setup I would prefer to use network commands to be safer.
Fourth Note:
In a real BGP confederations usage each mini AS has its own IGP running, because the target is to partition a very big network in smaller sub-domains.
We can say that a common IGP is not supposed between mini ASes but should be supported
Hope to help
Giuseppe
