Help WIC-1 SHDSL-V3 not working on Cisco 1841
Hello all and thanks in advance!
Here's my situation: I'm trying to setup a Back−to−Back link through G.SHDSL for testing purposes. I have a router 2620XM with a WIC-1 SHDSL-V3 card installed that allows me to set up the configuration parameters properly (I'm using this doc as a reference). On the other hand, I have a cisco 1841 with another WIC-1 SHDSL-V3 card that is causing me trouble.
Here's my sh ver from the 1841:
Router# sh ver
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(19), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 29-Feb-08 18:45 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 4 minutes
System returned to ROM by reload at 22:26:41 UTC Sat Oct 26 2013
System image file is "flash:c1841-advipservicesk9-mz.124-19.bin"
<output ommited>
export@cisco.com.
Cisco 1841 (revision 6.0) with 115712K/15360K bytes of memory.
Processor board ID FTX1050Z1UL
1 DSL controller
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Here's my sh diag:
Slot 0:
    C1841 2FE 2SLOT Mainboard Port adapter, 4 ports
    Port adapter is analyzed
    Port adapter insertion time 01:08:19 ago
    EEPROM contents at hardware discovery:
    Chassis MAC Address      : 001a.xxxx.xxxx
    MAC Address block size   : 34
    PCB Serial Number        : FOC10480XVR
    Hardware Revision        : 6.0
    Part Number              : 73-8191-07
    Board Revision           : B0
    Top Assy. Part Number    : 800-23434-05
    Deviation Number         : 87079
    Fab Version              : 04
    CLEI Code                : IPM7T00CRA
    RMA Test History         : 00
    RMA Number               : 0-0-0-0
    RMA History              : 00
    Product (FRU) Number     : CISCO1841
    Version Identifier       : V04
    Processor type           : 86
    Chassis Serial Number    : FTX1050Z1UL
    EEPROM format version 4
    EEPROM contents (hex):
      0x00: 04 FF C3 06 00 1A 6D 03 FB CC 43 00 22 C1 8B 46
      0x10: 4F 43 31 30 34 38 30 58 56 52 40 04 1B 41 06 00
      0x20: 82 49 1F FF 07 42 42 30 C0 46 03 20 00 5B 8A 05
      0x30: 88 00 01 54 27 02 04 C6 8A 49 50 4D 37 54 30 30
      0x40: 43 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
      0x50: 53 43 4F 31 38 34 31 89 56 30 34 20 D9 02 C1 40
      0x60: 09 86 C2 8B 46 54 58 31 30 35 30 5A 31 55 4C FF
      0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
<output ommited>
      0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    WIC/HWIC Slot 0:
    Serial 1T WAN daughter card
    Hardware revision 1.0             Board revision D0
    Serial number     36488878      Part number    800-01514-02
    FRU Part Number     WIC-1T=
    Test history      0x0             RMA number     00-00-00
    Connector type    Wan Module
    EEPROM format version 1
      0x20: 01 02 01 00 02 2C C6 AE 50 05 EA 02 00 00 00 00
      0x30: 68 00 00 00 08 05 18 01 FF FF FF FF FF FF FF FF
    WIC/HWIC Slot 1:
    GSI GSHDSL MULTI LINE ATM WIC
    Hardware Revision        : 0.0
    Top Assy. Part Number    : 800-26571-02
    Board Revision           : C0
    Deviation Number         : 0
    Fab Version              : 01
    PCB Serial Number        : FOC11293KH1
    RMA History              : 00
    Version Identifier       : V02
    Product (FRU) Number     : WIC-1SHDSL-V3
      0x00: 04 FF 40 04 DA 41 00 00 C0 46 03 20 00 67 CB 02
      0x10: 42 43 30 88 00 00 00 00 02 01 C1 8B 46 4F 43 31
      0x20: 31 32 39 33 4B 48 31 03 00 81 00 00 00 00 04 00
      0x30: 89 56 30 32 20 CB 8D 57 49 43 2D 31 53 48 44 53
      0x40: 4C 2D 56 33 FF FF FF FF FF FF FF FF FF FF FF FF
      0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    AIM Module in slot: 0
    Hardware Revision        : 1.0
    Top Assy. Part Number    : 800-27302-01
    Board Revision           : A0
    Deviation Number         : 0-0
    Fab Version              : 02
    PCB Serial Number        : FOC1320412P
    RMA History              : 00
    Product (FRU) Number     : AIM-VPN/SSL-1
    Version Identifier       : V01
      0x00: 04 FF 40 05 04 41 01 00 C0 46 03 20 00 6A A6 01
      0x10: 42 41 30 80 00 00 00 00 02 02 C1 8B 46 4F 43 31
      0x20: 33 32 30 34 31 32 50 03 00 81 00 00 00 00 04 00
      0x30: CB 8D 41 49 4D 2D 56 50 4E 2F 53 53 4C 2D 31 89
      0x40: 56 30 31 00 D9 02 40 C1 FF FF FF FF FF FF FF FF
In order to configure the DSL controller I enter the controller prompt by typing controller dsl 0/1/0:
Router(config-controller)#
But, once there, the only commands available for configuration are:
Router(config-controller)#?
Controller configuration commands:
  default      Set a command to its defaults
  description  Controller specific description
  exit         Exit from controller configuration mode
  help         Description of the interactive help system
  no           Negate a command or set its defaults
That's were I get stuck, since I don't have the proper commands available.
Additional info:
  • The OK LED is not lit on the front pannel of the card I'm having the issue with.
  • I installed the other WIC-1 SHDSL-V3 I have on both routers (2620xm and 1841), and the OK LED was lit and it allowed me to configure it properly.
Is the card deffective?
Any suggestions?
They will be greatly appreciated!
-Luciano
Luciano
Your testing does pretty well confirm that there is a problem with the WIC-1SHDSL-V3 card.
I am not convinced that it is a hardware problem with the VPN AIM. In looking through some Cisco documentation I found this statement about software requirements for the AIM:
The Cisco IPsec and SSL VPN AIM requires Cisco IOS Software Version 12.4(9)T or higher.
My opinion is that if you have access to another IOS image for 1841 (perhaps from another 1841 that you have) and especially if it were running the T train code rather than mainline, that it would be worth trying a different version of IOS on this 1841 and see if that helps.
It also occurs to me that we do not know what you plan to do with this 1841. It is possible that the 1841 will do what you need it to do even with the hardware accelerator for VPN not operating.
Rick
Rick
7 Replies 7
Richard Burts
Luciano
When I read the description of your problem my first thought was that it sounded like this card might not be supported. But ths link shows clearly that the 1841 does support this card and that the version of software that you are running should support the card.
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a00800921f0_ps221_Products_Data_Sheet.html
So we must look for some other explanation of the problem. Would you post the output of show controller for this card?
Rick
Rick
Hello Rick and thanks for your input!
I'm very grateful someone with your expertise is spending time trying to help me.
As you said, this doesn't seem to be a support issue based on the card's data sheet. Furthermore, I have another card (same exact model) which caused me no trouble when I installed it on the Cisco 1841 and also on a Cisco 2620xm.
I noticed that when I power up the router I get this output, that may be relevant in determining the cause of this behaviour:
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0x1658618
Self decompressing the image : #################################################
############################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
000504            UNKNOWN                  AIM
                0X00020000 Crypto module pools
0X0002          0X0001A800 Card in slot 0
0X04DA          0X00035000 Card in slot 1
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 6622227 bytes to IO Memory.
PMem allocated: 118489088 bytes; IOMem allocated: 15728640 bytes
              Restricted Rights Legend
export@cisco.com.
1 DSL controller
Press RETURN to get started!
*Oct 27 21:19:18.451: %XDSLWIC-3-FIRMWARE_DOWNLOAD_FAILURE: XDSLWIC R FPGA downl
oad fails. failure counts =  .
*Oct 27 21:19:18.451: %XDSLWIC-1-INITFAIL: XDSLWIC(0/1242), Init failed
*Oct 27 21:19:18.451: %AIM-2-AIMUNSUPP: AIM type 0x504 is not supported by this
platform.sslinit fn
*Oct 27 21:19:21.871: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
*Oct 27 21:19:21.875: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Enabled
*Oct 27 21:19:22.427: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to do
wn
*Oct 27 21:19:23.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
0, changed state to down
*Oct 27 21:19:24.819: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 27 21:19:25.143: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state
to administratively down
*Oct 27 21:19:25.143: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state t
o up
*Oct 27 21:19:25.411: %SYS-5-RESTART: System restarted --
*Oct 27 21:19:25.415: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
*Oct 27 21:19:25.723: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct 27 21:19:26.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/0, changed state to down
et0/1, changed state to up
*Oct 27 21:19:26.727: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to a
*Oct 27 21:19:28.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/1, changed state to down
It looks like the initialization process of the card fails and also that the system reboots (not sure about these 2 statements, just my interpretation). This is a good moment to make clear that I'm just a CCNA student
In regards to your request, Rick, I'm also unable to run the cmd "show controller DSL". It' s just not an available option. Look at this:
Router#sh controller ?
  Async         Async interface
  E1            E1 controller internal state
  FastEthernet  FastEthernet IEEE 802.3
  J1            J1 controller internal state
  Serial        Serial
  T1            T1 controller internal state
  |             Output modifiers
If I just enter the "show controllers" cmd, I get a lot of information about the FastEthernet 0/0 and 0/1 interfaces, plus the Serial interface, but nothing about dsl.
That's all the information I can provide you with right now. I certainly have no clue how to move on to solve this.
I'll gladly follow any suggestions you may have for me.
Many thanks again!
Luciano
Luciano
Thank you for the additional information. I believe that it is helpful. Certainly these messages indicate that there is a problem.
And if the firmware download failed it could explain why there are not many options for the controller in config mode.
This message also indicates a problem and I am not sure whether it is related to the first problem or is a second (unrelated) problem
platform.sslinit fn
I would suggest these steps to investigate this problem
- remove the WIC-1 SHDSL-V3 card from the router, boot the router, and see if there is a problem in the boot process. If so there is probably a problem in this 1841 which you need to deal with (hopefully it is covered under a maintenance contract so that you can request RMA of the router).
- if the boot without the card is successful, then power down the router and exchange the WIC-1 SHDSL-V3 card with the card that is running ok in the other 1841.
- If there is a problem on this router then the problem is probably with this router and is specific to this card. You will need to deal with it (perhaps you can deploy this 1841 somewhere that does not need WIC-1 SHDSL-V3).
- If the problem moves to the other 1841 then there is a problem with this particular WIC-1 SHDSL-V3 card.
Rick
Rick
Rick,
Thanks for your prompt response! I followed the steps you suggested:
First, I removed the WIC-1 SHDSL-V3 card from the router and I booted it up. Here's the output from the boot sequence (findings in bold):
PLD version 0x10
  ID            MEMORY_REQ         TYPE
000504            UNKNOWN                  AIM
Allocating additional 6643108 bytes to IO Memory.
States...
export@cisco.com.
*Oct 28 04:18:29.707: %AIM-2-AIMUNSUPP: AIM type 0x504 is not supported by this
platform.sslinit fn
*Oct 28 04:18:33.127: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
d to: Enabled
*Oct 28 04:18:33.683: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to do
wn
*Oct 28 04:18:34.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
*Oct 28 04:18:36.019: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 28 04:18:36.343: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state
*Oct 28 04:18:36.343: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state
*Oct 28 04:18:36.607: %SYS-5-RESTART: System restarted --
*Oct 28 04:18:36.611: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
*Oct 28 04:18:36.919: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct 28 04:18:37.343: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Oct 28 04:18:37.931: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to a
You pointed to an error I hadn't noticed before, which seems to be unrelated to the issue with the WIC-1 SHDSL-V3 card. According to this article, it is definitely a hardware issue (you may know it better than these folks). Unfortunately, the equipment is no longer covered under a maintenance contract (will have to deal with this failure, I´m not sending the router to the UK ).
Afterwards, I installed the second SHDSL-V3 card I have on this (the same) router, and booted it up again. Here's what I got:
PLD version 0x10
  ID            MEMORY_REQ         TYPE
000504            UNKNOWN                  AIM    -------------> Already known failure
Allocating additional 6619839 bytes to IO Memory.
States...
export@cisco.com.
1 DSL controller
*Oct 28 04:59:28.447: %AIM-2-AIMUNSUPP: AIM type 0x504 is not supported by this  --------->Already known failure
platform.sslinit fn
*Oct 28 04:59:31.871: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
d to: Enabled
*Oct 28 04:59:32.427: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to do
wn
*Oct 28 04:59:33.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/
*Oct 28 04:59:34.815: %SYS-5-CONFIG_I: Configured from memory by console
*Oct 28 04:59:35.135: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state
*Oct 28 04:59:35.135: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state
*Oct 28 04:59:35.403: %SYS-5-RESTART: System restarted --
*Oct 28 04:59:35.407: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing
a cold start
*Oct 28 04:59:35.715: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Oct 28 04:59:36.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
*Oct 28 04:59:36.719: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to a
But, this time, when issuing:
Router#show inv
NAME: "chassis", DESCR: "1841 chassis"
PID: CISCO1841         , VID: V04 , SN: FTX1050Z1UL
NAME: "WIC/HWIC 0", DESCR: "WAN Interface Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 36488878
NAME: "WIC/HWIC 1", DESCR: "WAN Interface Card - ATM (With multi line G.SHDSL mo
dule)"
PID: WIC-1SHDSL-V3     , VID: V02 , SN: FOC12212XAJ
Router#sh controller dsl
DSL 0/1/0 controller DOWN
SLOT 0: Globespan xDSL controller chipset
DSL mode: Not Trained
No frame mode configured
Line Re-activated 0 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
FPGA Revision: 0xB2
        Current 15 min CRC: 0
        Current 15 min LOSW Defect: 0
        Current 15 min ES: 0
        Current 15 min SES: 0
        Current 15 min UAS: 0
        Previous 15 min CRC: 0
        Previous 15 min LOSW Defect: 0
        Previous 15 min ES: 0
        Previous 15 min SES: 0
        Previous 15 min UAS: 0
Line-0 status
Chipset Version:  0
Firmware Version:  R3.0.1
Modem Status:  un checked mode, Status 8DAF
Last Fail Mode:  No Failure status:0x0
Dying Gasp: Present
And finally:
Router(config)#controller dsl 0/1/0
  dsl-mode               SHDSL mode
  ignore-error-duration  Number of seconds errors such as CRC are ignored while
                         the line is traning (default is 0)
  line-term              Customer Premise or Central Office
  loopback               XDSL loopback test
  mode                   Configure the xdsl controller mode
  shutdown               Shutdown the xdsl controller
  snr                    SNR
All seems to be OK with the second WIC-1 SHDSL-V3: no "Firmware_download_failure" error message during bootup, I was able to issue "sh controllers dsl" and all commands are available in the config mode.
I  guess we can conclude that "there's something wrong" with the first  WIC-1 SHDSL-V3. I had already tested that one on the other router  previously with the same results (same errors). That would be the "good news".
Bad news is that now I have found that not only the S.HDSL card doesn't work, but also the VPN AIM is faulty too.
Would you agree with me Rick?
Thanks in advance!!!!
-Luciano
Luciano
Rick
Rick
Hi Rick!
Thanks for your feedback! The situation is clear to me now. One of the WIC-1SHDSL-V3 cards is clearly damaged. The Cisco IPSec and SSL VPN AIM is not necessarily defective. I will have to look for an alternative solution in regards to the G.SHDSL back-to-back link (maybe I'll stick to my WIC-1T cards, for now). And the VPN hardware acceleration is not an issue for me right now. I´ll try upgrading the IOS if necessary later on.
I must say it´s been a pleasure dealing with you, you've been very kind and generous and I really appreciate it.
Hope we'll keep seeing around in these forums!
Warm regards from Argentina,
Luciano
Luciano
It has been an interesting discussion and I have enjoyed the interaction with you. I am glad that my suggestions were helpful. Thank you for using the rating system to mark this question as answered. I do hope to see more of your activity in the forums.
Rick
Rick
