HELP with 1941 Router setup and gateway config
pinnaclecsg
Thank you in advanced for helping me with this issue.
We are moving from a Cisco Small Business Router SA520 to a 1941W. We have a static ip address and used the basic CP Express Wizard setup wizard. I then used CP normail edition entered the ip address of the external connect on g0/0 and the internal lan on 0/1, easy enough. We then configured the NAT but still can not get outside access.
The only configuring from the isp (comcast business internet) and the orginal SA520 router that I could not find any to enter in this router is the "Default Gateway"........... is this hidden? or am I just lost
Thanks again
Richard Burts
Cory
I am not sure that I understand your question, and part of that may be because I am not familiar with the SA520. I am guessing that you are looking for how to set the default gateway for the router. On the 1941 that is usually done by configuring a static default route. It would look something like this:
ip route 0.0.0.0 0.0.0.0
Rick
Rick
