Showing results forĀ
Search instead forĀ
Did you mean:Ā
Help with 2901 with a new ISP
ctusa2003am
We were using Ge 0/1 with old ISP (10 Mb Ethernet over Fiber) which is now inactive.
Now we using Cablemodem on Fe 0/0/3 and the above ISP is allowing us to use his IPs through this cablemodem.
We are now getting a new Fiber Ethernet (20Mb).
I have put the running config of the above router (2901) below.
So here are my questions/confusions:
Which interface we can use for the upcoming 20Mb line. I think Ge 0/0 is available. Once the new line comes, Can I start working with usinge (Ge 0/0), without affecting any current/live access? Once tested fine, I can make the new 20Mb line as 'production'.
I will keep the existing config/interfaces unaffected which will help us quickly reverting the access back in case something goes wrong with the new line.
Also if some can provide more help for the new config will be great, since this is a little more complicated scenario than I am used to. Llearning a lot lately, but am concerned since this is production system.
Also wanted to give the input that we have 2 ASA 5510 in Active-Standby mode with NATs and ACL etc. and I was thinking that I can break the failover and use one of the 5510 with the new line.
Any help/suggestion is appreciated.
Config below--------------------------------------------------------------
Building configuration...
Current configuration : 4659 bytes
! Last configuration change at 01:38:49 EDT Tue Jul 14 2015
! NVRAM config last updated at 01:38:52 EDT Tue Jul 14 2015
version 15.1
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname router
boot-start-marker
boot system flash flash:/c2900-universalk9-mz.SPA.151-4.M6.bin
boot system flash flash:/c2900-universalk9-mz.SPA.151-4.M4.bin
warm-reboot
boot-end-marker
logging buffered 65536
enable password …………………………
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
no ipv6 cef
no ip source-route
ip cef
ip vrf cablemodem
 rd 7922:1
 route-target export 7922:1
 route-target import 7922:1
ip name-server 204.213.176.1
license udi pid CISCO2901/K9 sn FTX153680T5
license boot module c2900 technology-package datak9
redundancy
track 1 ip sla 1 reachability
 delay down 10
policy-map opteman10-policy
 class class-default
  shape average 10000000 250000 0
  fair-queue
  random-detect
interface Tunnel20
 description Tunnel to oldISP
 bandwidth 10000
 ip address 204.x.x.x 255.255.255.252
 ip mtu 1476
 ip tcp adjust-mss 1436
 keepalive 10 3
 tunnel source Vlan13
 tunnel destination 69.x.x.x
 tunnel vrf cablemodem
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description oldISP Internet
 bandwidth 10000
 duplex full
 speed 100
 service-policy output opteman10-policy
interface ATM0/1/0
 no ip address
 no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
 pvc 0/35
  oam-pvc manage
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface ATM0/2/0
 no ip address
interface ATM0/2/0.1 point-to-point
 pvc 0/35
  oam-pvc manage
interface ATM0/3/0
 no ip address
interface ATM0/3/0.1 point-to-point
 pvc 0/35
  oam-pvc manage
interface FastEthernet0/0/0
 switchport access vlan 10
 no ip address
interface FastEthernet0/0/1
 switchport access vlan 11
 no ip address
interface FastEthernet0/0/2
 switchport access vlan 12
 no ip address
interface FastEthernet0/0/3
 switchport access vlan 13
 no ip address
interface Vlan1
 no ip address
interface Vlan10
 description Lightstat #1
 ip address 205.x.x.x  255.255.255.240
 ip verify unicast reverse-path
interface Vlan11
 description Lightstat #2
 ip address 65.x.x.x 255.255.255.192
interface Vlan12
 description Lightstat #3
 ip address 65.x.x.x 255.255.255.240
interface Vlan13
 description Cable Modem Connection
 ip vrf forwarding cablemodem
 ip address 71.9.x.x 255.255.255.248
interface Dialer1
 description oldISP ADSL
 mtu 1492
 ip address negotiated
 no ip redirects
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer idle-timeout 0 either
 dialer hold-queue 100
 dialer persistent
 ppp pap sent-username lstat@oldISPnklttjhklpfg6lgh78x.net password 7 15405849063F392A
 ppp multilink
 no cdp enable
ip default-gateway 204.x,x,x
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 204.x.x.x track 1
ip route 0.0.0.0 0.0.0.0 204.x.x.x 10
ip route 0.0.0.0 0.0.0.0 Dialer1 250
ip route 10.0.0.0 255.0.0.0 Null0
ip route 65.x.x.x 255.255.255.240 Null0 254
ip route 65.x.x.x 255.255.255.192 Null0 254
ip route 127.0.0.0 255.0.0.0 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip route 205.x.x.x 255.255.255.240 Null0 254
ip route vrf cablemodem 0.0.0.0 0.0.0.0 71.9.x.x
ip sla 1
 icmp-echo 204.x.x.x source-interface GigabitEthernet0/1
ip sla schedule 1 life forever start-time now
access-list 99 permit 204.x.x.x 0.0.0.3
no cdp run
snmp-server community oldISPstats RO 99
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password .;lll;…………
 login
 transport input all
scheduler allocate 20000 1000
ntp update-calendar
ntp server 204.x.x.x
end
User Access Verification
router#sh ip int brief
Interface                 IP-Address      OK? Method Status                Prot                                         ocol
Embedded-Service-Engine0/0 unassigned     YES NVRAM  administratively down down
GigabitEthernet0/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1         204.x.x.x YES NVRAM  up                    up
ATM0/1/0                  unassigned      YES NVRAM  down                  down
ATM0/1/0.1                 unassigned      YES unset  down                  down
ATM0/2/0                   unassigned      YES NVRAM  up                    up
ATM0/2/0.1                 unassigned      YES unset  up                    up
ATM0/3/0                   unassigned      YES NVRAM  up                    up
ATM0/3/0.1                 unassigned      YES unset  up                    up
FastEthernet0/0/0         unassigned      YES unset  up                    up
FastEthernet0/0/1         unassigned      YES unset  up                    up
FastEthernet0/0/2         unassigned      YES unset  up                  up
FastEthernet0/0/3         unassigned      YES unset  up                    up
Dialer1                  32.x.x.x  YES IPCP   up                    up
Tunnel20                   204.x.x.x  YES manual up                    up
Virtual-Access1           unassigned      YES unset  up                    up
Virtual-Access2           unassigned      YES unset  down                  down
Virtual-Access3           unassigned      YES unset  up                    up
Vlan1                    unassigned      YES unset  down                  down
Vlan10                     205.x.x.x  YES NVRAM  up                    up
Vlan11                     65.x.x.x    YES NVRAM  up                    up
Vlan12                     65.x.x.x   YES NVRAM  up                    up
Vlan13                     71.9.x.x     YES manual up                    up
router#
7 Replies 7
Ganesh Hariharan
See , Your scenario is to do cutover to new cable modem link from old link.
Assumming you are having the same provider and they have aggreed to route your pubic ips from new cable modem on new fiber link.
Get the stability test of the link and you need to same configuration on new port same.As you cant have same ip address on both the ports at same time.
Hope it Helps..
-GI
Hi Ganesh,
Thanks for your comments/input. Actually we currently, are using CableModem (Fe0/0/3-- Vlan13), as you will see from the config. The old ISP (10Mb line on Ge 0/1) line is inactive but he was nice to still let us use his IP via Cable Modem (Vlan 13 above).
Now we are getting a 20Mb line ( and a new 32 IPs) for which I need help with Configuration.
Can I configure Ge 0/0 with the new Line/new IPs. I just want to make sure that while I am working with the new line configuration, it does not affect the existing connections since that's all we have. Once the new line works fine, we shall remove the old routing from Cablemodem and use that just for phones and wi-fi etc.
I apologize if I didn't articulate properly before.
Ashok
Hello Ashok,
Adding an ip address in new port will not give any issue unless you point your defaul route or routing configiration towards the new interface.
Hope it Helps..
-GI
bolds04
Yes you should be able to build your config to GE0/0 with the new 20mb line.  Just make sure to put it in a different VRF.
You currently have Vlan 13 in VRF cablemodem.  Just build a new vrf - "VRF NEWLINE"  with the proper IP addressing ect. and verify connectivity.  Once verified, you can then reconfigure your default gateway to the new VRF.
Ping VRF NEWLINE 8.8.8.8
Ping VRF NEWLINE x.x.x.x - Carrier IP
Then change your default route on your vlan 13 to the new VRF.  Hope this helps.
B
Hi B,
thanks for your post. It does help. Questions:
Please correct me if I am wrong, wouldn't changing the Def.route  on Vlan 13, will stop using the cablemodem connection?
What should I do to make sure that the current cable modem/configuration is unaffected, so if anything goes wrong (till everything is tested well for a few days) I could quickly revert back the way we are.
I was hoping to I could find a configuration where I use this available physical int Ge 0/0 and configure with the new line/IPs and start testing by making this as the higher priority 'ip route' and if things go wrong then next route (i.e. cablemodem) becomes active.
Is it a fair question and if yes how can I do that.
Ashok
Perhaps I wasn't clear enough.
You are not changing the vrf on the cablemodem Vlan 13 till you are finished testing the new line and are ready to migrate traffic over to it.
Suggestions - If I were you, what I would do, is create a new VRF and new vlan.  Test connectivity and then change your vlan 13 over to the new vrf.
Once you've migrated to the new line THEN you can build IP SLA statements into your configs to flip traffic to another pipe should one go down.
Let me know if that clears things up.  B
Hi B,
This VRF is kind of new to me and I defintely learnt a lot. Thanks to you and Ganesh both. Your last post cleared up things a little more.
Another question I have is after creating a new vrf and assinging to the phy int ge0/0 (with the new vlan), can I just keep the old one as well and put some policy so that if the new line (20Mb) is down the old 'cablemodem' line gets in operation?
Ashok
