Help with 867VAE config
cymak
Hi all,
Sorry but I'm a newbie to CLI so am trying to configure a router through CCP 2.8.
Problem I'm having I think .... is routing between the vlan (Local LAN) and the WAN interface.
From CCP I can ping internet addresses but cant do so from a local IP.  I have attached running config, hope someone can help.  Not sure if I'm giving enough info ...  Thanks!
Mark Malone
hey if I'm reading this right and its your wan port it should be ip natr outside and lan side gets ip nat inside , that's all I see wrong at first glance
interface GigabitEthernet1
description $FW_OUTSIDE$$ETH-WAN$
no ip dhcp client request tftp-server-address
ip address 87.192.96.118 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside--------------------------ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
Mark Malone
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
Thank you !!!
For some reason  ip NAT outside would not keep its settings as I had changed it before hand, I had to remove the NAT and save config and reboot router then rerun the NAT wizard and it kept the settings this time :)
no problem glad you sorted it :)
Glenn Martin
Moving this Discussion to the correct community.
