BGP Issue with IPSEC Tunnels
John Gentle
I have an issue with IPSEC tunnels and my BGP connection.  I am going to try to lay out the topology as best as possible, so here goes. Please bear with me as a bit complicated and i have run in to something i can't figure out.
I have 2x ISPs that come in to a stacked 3750 switch on seperate VLANs (1501 and 1502).  From a 2900 is connected to the 3750's and providing BGP for my IPs.  Both interfaces feed back to the 3750.  Then from the 3750 i have core routers (in this case I am referring to a 3845) that provides internal NAT and IPSEC tunnels out to my remote locations.
In the 3750 the Vlan interface for each ISP has one of their IPs from the /29 they give me for BGP assigned to it so i can gain access remotely.
The core router has ip route 0.0.0.0 0.0.0.0 x.x.x.1 which is the 2900 router providing BGP and the x.x.x.1 is one of my IPs in my range (ie not provided by the ISP)
The edge router providing BGP has:
ip route a.a.a..201 255.255.255.255 GigabitEthernet0/0.1501  (.201 is the ISPs gateway)
ip route y.y.y.137 255.255.255.255 GigabitEthernet0/0.1502  (same as above, .137 is the ISPs gateway)
Here is where the problem comes. The 3750 stack for reasons unknown to me MUST have for the IPSEC traffic to work:
ip route 0.0.0.0 0.0.0.0 a.a.a.201
ip route 0.0.0.0 0.0.0.0 y.y.y.137 secondary
If i remove those route statements from the 3750 IPSEC traffic fails, however other traffic that is simply NAT seems to be fine - both in and out.  The problem with that is if the route that isn't secondary goes down then everything dies off until i reverse it.  Aside from that basically everything is going out the a.a.a.201 ISP regardless of AS routes which is problematic if one gets extremely loaded.
There doesn't seem to be an issue with BGP per se because i can check looking glasses and see my routes advertised properly.
My question and problem is why do i have to have the ip route statements on the 3750 stack?  I am quite sure you will need additional info to help me, so thanks in advance for any insight you can offer.
Thanks in advance for any assistance!!
John
9 Replies 9
Hello John,
is this your setup ?
Remote locations (IPSec/NAT) <--> 3845 --> 3750 Stack --> 2900 --> ISP1/ISP2 ?
Not exactly.  Remote locations (IPSec/NAT) <-ISP1/2 Internet-> 3750 stack ---> 2900 (BGP) ---> 3750 stack ---> 3845
John,
I have looked at the configs. Removing the default routes on the 3750 would just leave the connected routes in the routing table. Can you issue a 'show ip route' on the 3750 for both the IPSec traffic and the NAT traffic ? And post the output ?
I should add one small correction on the 3750.  The actual route statements are:
ip route 0.0.0.0 0.0.0.0 y.y.y.137 2
I incorrectly had y.y.y.137 secondary but when i just put it back in there to generate the "show ip route" i realized my mistake.  None the less, from the 3750 with both ISP1 and ISP2 connected and all BGP tables on the 2900 updated this is what i get with a sh ip rou
at1-wanstaack-1# sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is a.a.a.201 to network 0.0.0.0
     a.0.0.0/29 is subnetted, 1 subnets
C       a.a.a.200 is directly connected, Vlan1501
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.251.0 is directly connected, Vlan251
S*   0.0.0.0/0 [1/0] via a.a.a.201
I am lost on your physical setup. The output is from at1-wanstaack-1, while your 3750, the one with the two default static routes, is datacenter1-wanstack-1 ? Can you make a schematic drawing of your physical setup ? The idea with showing the routing table was to find out why NAT traffic gets routed even without the default routes, but IPSec traffic doesn't. A TRACEROUTE for both a NAT and IPSec destination would work, too...
John,
first, I would fix the BGP load balancing and redundancy. There are several ways to configure this. The links below gives sample configurations for dual BGP with community string load balancing and dual BGP with AS-prepend load balancing.
http://showipbgp.com/bgp-configurations/40-cisco/118-4-4-2-cisco-dual-bgp-with-community-string-load-balancing.html
http://showipbgp.com/bgp-configurations/40-cisco/114-4-3-2-cisco-dual-bgp-with-as-prepend-load-balancing.html
If that gets too confusing, post the config of the 2900 router (the one connected to both ISPs) and we can put the right config in there.
Either way, with both configs you need two default routes pointing to both ISPs respectively. The keyword 'secondary' would not be necessary. I am not sure how this would influence your IPSec traffic. Can you post the configs of the 3750 stack and the 3845 as well ?
Here are our three configs from the switch.  Thank again.  I have been stumped off and on since December of last year and now it is sort of a problem that the more I think about, the more I need to resolve before it bites me hard.
3750 Stack Configuration
datacenter1-wanstack-1#sh run
Building configuration...
Current configuration : 7431 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service internal
service unsupported-transceiver
hostname datacenter1-wanstack-1
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa session-id common
clock timezone EASTERN -4
switch 1 provision ws-c3750v2-24ts
switch 2 provision ws-c3750v2-24ts
system mtu routing 1500
vtp domain domain.com
vtp mode transparent
ip routing
ip name-server 172.16.250.12
no errdisable detect cause gbic-invalid
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery interval 360
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 251
vlan 500
  private-vlan primary
  private-vlan association 2000-2002
vlan 1501-1502
vlan 2000
 name To-3845
  private-vlan community
vlan 2001
vlan 2002
interface FastEthernet1/0/1
 description datacenter1-edge-1 Ge0/1
 switchport private-vlan mapping 500 2000-2002
 switchport mode private-vlan promiscuous
interface FastEthernet1/0/2
 description datacenter1-core-1 Ge0/0
 switchport private-vlan host-association 500 2000
 switchport mode private-vlan host
interface FastEthernet1/0/3
 switchport access vlan 1501
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
 description To datacenter1-manswitch-1
 switchport access vlan 251
interface FastEthernet1/0/23
 description ISP1 100mb
 speed 100
 duplex full
interface FastEthernet1/0/24
 description datacenter1-edge-1 Ge0/0
 switchport mode trunk
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface FastEthernet2/0/1
 description datacenter1-edge-2 Ge0/1
 shutdown
interface FastEthernet2/0/2
 description datacenter1-core-2 Ge0/0
 shutdown
interface FastEthernet2/0/3
 description RMSG Switch Gi1/0/1
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
interface FastEthernet2/0/11
interface FastEthernet2/0/12
interface FastEthernet2/0/13
interface FastEthernet2/0/14
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
interface FastEthernet2/0/18
interface FastEthernet2/0/19
interface FastEthernet2/0/20
interface FastEthernet2/0/21
interface FastEthernet2/0/22
interface FastEthernet2/0/23
 description ISP2 100mb
 switchport access vlan 1502
 speed 100
 duplex full
interface FastEthernet2/0/24
 description datacenter1-edge-2 Ge0/0
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface Vlan1
 no ip address
interface Vlan251
 ip address 172.16.251.98 255.255.255.0
interface Vlan500
 ip address x.x.x.7 255.255.254.0
 private-vlan mapping 2000-2002
interface Vlan1501
 ip address a.a.a.205 255.255.255.248
interface Vlan1502
 ip address y.y.y.141 255.255.255.248
ip classless
ip http server
ip http secure-server
snmp-server community nagios-ro RO
2900 Router Providing BGP
datacenter1-edge1-1#sh run
Current configuration : 4280 bytes
! Last configuration change at 13:15:55 EASTERN Wed Aug 24 2016 by myadmin
version 15.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service sequence-numbers
no service password-recovery
no service dhcp
hostname datacenter1-edge1-1
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 50000
logging rate-limit 10000
logging console warnings
no logging monitor
aaa new-model
clock timezone EASTERN -4 0
no ip bootp server
ip domain name domain.com
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description To datacenter1-wantsack1 Fa1/0/24
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/0.1501
 encapsulation dot1Q 1501
 ip address a.a.a.202 255.255.255.248
 ip access-group Outbound out
 ip virtual-reassembly in
interface GigabitEthernet0/0.1502
 encapsulation dot1Q 1502
 ip address y.y.y.138 255.255.255.248
interface GigabitEthernet0/1
 description datacenter1-wanstack Fa1/0/1
 ip address x.x.x.2 255.255.254.0
 no ip redirects
 no ip unreachables
 ip local-proxy-arp
 ip route-cache same-interface
 glbp 0 ip x.x.x.1
 glbp 0 priority 110
 glbp 0 preempt delay minimum 30
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 ip address 172.16.251.97 255.255.255.0
 duplex auto
 speed auto
router bgp MYASNUMBER
 bgp router-id x.x.x.1
 bgp log-neighbor-changes
 network x.x.x.0 mask 255.255.254.0
 neighbor a.a.a.201 remote-as 1111
 neighbor a.a.a.201 route-map localonly out
 neighbor y.y.y.137 remote-as 2222
 neighbor y.y.y.137 route-map localonly out
ip forward-protocol nd
ip as-path access-list 10 permit ^$
no ip http server
ip http authentication local
no ip http secure-server
ip route a.a.a.201 255.255.255.255 GigabitEthernet0/0.1501
ip access-list extended ACL_SSHACCESS
 permit ip x.x.x.0 0.0.0.31 any
ip access-list extended Outbound
 deny   ip 192.168.0.0 0.0.255.255 any log-input
 deny   ip 172.16.0.0 0.15.255.255 any log-input
 deny   ip 10.0.0.0 0.255.255.255 any log-input
 deny   udp any any eq netbios-ns
 deny   udp any any eq netbios-dgm
 deny   udp any any eq netbios-ss
 permit ip x.x.x.0 0.0.1.255 any reflect alliptraffic timeout 120
route-map localonly permit 10
 match as-path 10
3845 Router doing IPSEC and NAT in our datacenter
datacenter1-core1-1#sh run
Current configuration : 66924 bytes
! Last configuration change at 02:32:50 UTC Wed Sep 28 2016 by myadmin
! NVRAM config last updated at 23:01:43 UTC Mon Oct 3 2016 by myadmin
version 15.1
hostname datacenter1-core1-1
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 172.16.201.12
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn
redundancy
track 1 interface GigabitEthernet0/0 line-protocol
track 2 interface GigabitEthernet0/1 line-protocol
 description datacenter1-wanstack1.1 Fe1/0/4
 ip address x.x.x.5 255.255.254.0
 ip access-group ACL_PRIMARY-WAN-FIREWALL in
 ip nat outside
 standby 2 ip x.x.x.4
 standby 2 timers 1 3
 standby 2 priority 200
 standby 2 preempt
 standby 2 track 1 decrement 110
 standby 2 track 2 decrement 110
 duplex auto
 speed auto
 media-type rj45
 crypto map AES_MAP
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/1.100
 encapsulation dot1Q 100
 ip address 172.16.100.252 255.255.254.0
 ip access-group ACL_PN in
 ip nat inside
 standby 1 ip 172.16.100.254
 standby 1 timers 1 3
 standby 1 priority 200
 standby 1 preempt
 standby 1 track 1 decrement 110
 standby 1 track 2 decrement 110
interface GigabitEthernet0/1.105
 encapsulation dot1Q 105
 ip address 172.16.105.252 255.255.255.0
 ip access-group ACL_SFP in
 ip nat inside
 standby 1 ip 172.16.105.254
 standby 1 preempt
no ip http server
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
ip route 192.168.2.0 255.255.255.0 GigabitEthernet0/0
ip route 192.168.3.0 255.255.255.0 GigabitEthernet0/0
ip route 192.168.5.0 255.255.255.0 GigabitEthernet0/0
ip route 192.168.6.0 255.255.255.0 GigabitEthernet0/0
control-plane
mgcp profile default
line con 0
 logging synchronous
line aux 0
line vty 0 4
 access-class ACL_SSHACCESS in
 transport input ssh
scheduler allocate 20000 1000
ntp server 172.16.201.16
end
John,
I might be missing something, but since you say the 3845 is doing NAT and IPSec, I cannot find either the ip nat inside or outside source statements, nor the crypto map that is mentioned, AES_MAP. Is this the full config of the 3845 ?
I took a bit out and should have left some of those as examples.  Sorry and again, much thanks!
3845 Router doing IPSEC in our datacenter
version 15.1
boot-start-marker
boot-end-marker
aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
redundancy
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
crypto isakmp key datacenter1-PN1.9UwAGVwsfsfahtryu63545k21ddfgjbBik address c.c.c.2
crypto isakmp key datacenter1-PN2.sOH52g4Ok5TBvJCAFQtcYwrOjC0OPKxpp1 address d.d.d.98
crypto ipsec transform-set AES_SET esp-aes 256 esp-sha-hmac
crypto map AES_MAP 10 ipsec-isakmp
 set peer c.c.c.2
 set transform-set AES_SET
 match address ACL_PN1
crypto map AES_MAP 12 ipsec-isakmp
 set peer d.d.d.98
 match address ACL_PN2
 ip nat outside
 standby 2 preempt
 duplex auto
 speed auto
 media-type rj45
 crypto map AES_MAP
 no ip address
 duplex auto
 speed auto
 media-type rj45
 ip nat inside
 standby 1 preempt
 ip nat inside
 standby 1 preempt
no ip http server
ip nat inside source static tcp 172.16.100.41 25 x.x.x.50 25 extendable
ip nat inside source static tcp 172.16.100.41 443 x.x.x.50 443 extendable
ip nat inside source static tcp 172.16.100.12 636 x.x.x.51 636 extendable
ip nat inside source static udp 172.16.100.12 636 x.x.x.51 636 extendable
ip nat inside source static tcp 172.16.100.138 443 x.x.x.52 443 extendable
ip nat inside source static tcp 172.16.100.138 943 x.x.x.52 943 extendable
ip access-list extended ACL_NAT
 remark *** Start of Denys for PN1
 deny   ip 172.16.100.0 0.0.1.255 192.168.6.0 0.0.0.255
 remark *** Start of Denys for PN2
 deny   ip 172.16.100.0 0.0.1.255 192.168.5.0 0.0.0.255
 remark *** Permit Everything not denied above
 permit ip any any
ip access-list extended ACL_PN2
 permit ip 172.16.100.0 0.0.1.255 192.168.5.0 0.0.0.255
ip access-list extended ACL_PN1
 permit ip 172.16.100.0 0.0.1.255 192.168.6.0 0.0.0.255
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 transport input ssh
end
