Help with cisco 887, HELP ME PLEASE!!!
el_moshin
hello
I have a cisco 887 router security and need to open ports: 25, 1723, 110, 53, 443, 987 that I am implementing a server with exchange and other things I need to open those ports on the router firewall and also the internal IOS did not block these ports, someone could give me how to configure to avoid problems?, thanks your help
Marcelo Ramos Olivares
hello
Peter Paluch
Marcelo,
There are different types of firewalls in Cisco IOS, and it depends on your particular configuration how the ports should be opened. Can you post your current running-config (removing the sensitive information, of course)?
Best regards,
Peter
Latchum Naidu
Hi Marcelo,
If you want open the above ports from outside (internet) you need to have configure NAT & PAT for that particular server in order to accessible from outside through the specific ports.
Please rate the helpfull posts.
Naidu.
