Help with CISCO-887VA adsl over pots and PPPoE with dynamic IP
angkw
I've got problem trying to connect the CISCO-887VDSL/ADSL OVER POTS ROUTER to internet. Only got the LAN part working.
I'm trying to setup PPPoE with dynamic IP
Followed CISCO's documentations but the commands used were not recognized by the router. Any simple working config for me to follow will be enough.
I'll appreciate any help. Thanks a lot!
here's  my config.
! Last configuration change at 08:31:51 UTC Sat Feb 11 2012
version 15.1
no service pad
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 10.0.0.1 10.0.0.149
ip dhcp excluded-address 10.0.0.199 10.0.0.254
ip dhcp pool sdm-pool
import all
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server x.x.x.x x.x.x.x.x
lease 0 2
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FGLxxxxxxx
controller VDSL 0
ip ftp username cisco
ip ftp password cisco
interface Ethernet0
pppoe enable group global
pppoe-client dial-pool-number 1
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip directed-broadcast
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password 0 xxxx
ppp pap sent-username xxxx password 0 xxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard 1
permit 10.0.0.0 0.0.0.255
no cdp run
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Not applicable
Try to check with your ISP the modem string to use for VDSL
and some ISP support direct dhcp on Ethernet0 without PPPoE.
An equivalent config is working for me in Switzerland with Swisscom.
N.B. "modem" under VDSL controller is enable using service internal !
service internal
controller VDSL 0
operating mode vdsl2
modem co5
ip source-route
ip cef
import all
dns-server 8.8.8.8
lease 0 2
interface Ethernet0
ip address dhcp
ip nat outside
interface Vlan1
ip nat inside
ip nat inside source list 23 interface Ethernet0 overload
access-list 23 permit 10.0.0.0 0.0.0.255
end
mhnothman
i think you may issue no shutdown for ethernet 0 as well
