Help with Configuring a 2811 Cisco Router for use with ISP
Hello!
So I found this 2811 Cisco router & wanted to hook it up in my house to use with my existing network equipment.
I thought that it would be pretty straight-forward, but I can't seem to get it to work properly. I've looked online to find the correct commands, but none of them seem to be working right.
After messing about with it for some time now, I've just erased the nvram, & reloaded the router until I get some proper info from you nice folks!
I'm not sure what info you may need in regards to how the router needs to be configured, but I'll provide what is necessary upon request.
Thanks!
23 Replies 23
depends on where in your network the router needs to be. Can you provide a schematic drawing of what you have and where you want the router to be ?
Sure, so basically
ISP ---> 2811 ---> WiFi
or see photo for better idea.
with your ISP connected to FastEthernet0/0 on your router, a basic configuration would look like this:
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
Alright thanks. I'm going to give that a go right now. I'll let you know the results shortly.
As a side note, I used almost the same configuration as this before, only my default route wasn't the same as yours. That could have been one of my issues.
Anyhow, I'll be back in a moment.
Also, does the router interface connected to the modem pull an IP address ?
I have made a few adjustments to the config, give it a try (changes are marked in bold):
Current configuration : 1173 bytes
version 12.4
service password-encryption [redacted]
hostname [redacted]
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret [redacted]
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map ISP interface FastEthernet0/0 overload
route-map ISP permit 10
match ip address 1
match interface FastEthernet0/0
control-plane
line con 0
password
login
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
You also might want to log into the modem and find out the IP address assigned to it. Use that address in the default route. So instead of:
type
ip route 0.0.0.0 0.0.0.0 x.x.x.x (the IP address assigned to the modem)
Let me do that real quick. I didn't see this reply when I just posted.
with the current configuration, your clients would need either static IP addresses or a DHCP assigned address from a server on your network.
You can also have the router dish out IP addresses. Add this to your config:
ip dhcp excluded-address 192.168.1.1
ip dhcp pool DHCP_LAN
 network 192.168.1.0 255.255.255.0
 dns-server 8.8.8.8 8.8.8.4
 default-router 192.168.1.1
OK, added the default-route via the modem's ip.
Also added the DHCP Pool as specified.
Care for an updated running-config to help troubleshoot?
Building configuration...
Current configuration : 1379 bytes
version 12.4
hostname
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
ip route 0.0.0.0 0.0.0.0 x.x.x.x (modem's ip add)
no ip http server
match ip address 1
control-plane
line con 0
password xxxxx7xx7x8x8x
login
line aux 0
line vty 0 4
login
end
Hold up...might be working now. My PC didn't want to pull an address right away, but I think it's got it now. Verifying...
Yep, looks like we got it now! Everything checks out good.
Sorry I had to leave. Past midnight in my timezone...:)
Glad to hear it is working !
