Help with configuring VOIP
temkintegegn
Hello everyone
I have configured everything, OSPF, PAT, DHCP server.. I am ordered to configure voip on another router called VOIP. IP Phones gets ip address (voice ip address 10.172.32.0 255.255.248.0) successfully  but somehow, they don't get line number and when I type show ephone, it shows me unregistered, there is no registered phone. I uploaded all necessary configuration. Can you help with this?
the IP addresses of the Edge and the VoIP router are reversed. Make the changes marked in bold:
EDGE
interface FastEthernet0/0.8
encapsulation dot1Q 8
--> ip address 10.172.32.2 255.255.248.0
ip helper-address 10.172.47.10
ip helper-address 10.172.47.8
VOIP
VOIP#sh run
Building configuration...
Current configuration : 1663 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname VOIP
ip dhcp excluded-address 10.172.32.1 10.172.32.10
ip dhcp pool vlan8
network 10.172.32.0 255.255.248.0
default-router 10.172.32.1
option 150 ip 10.172.32.1
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX10175ZF1-
no ip domain-lookup
spanning-tree mode pvst
--> ip address 10.172.32.1 255.255.248.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
--> ip route 0.0.0.0 0.0.0.0 10.172.32.2
ip flow-export version 9
telephony-service
max-ephones 40
max-dn 144
ip source-address 10.172.32.1 port 2000
auto assign 1 to 100
ephone-dn 1
number 1010
ephone-dn 2
number 1020
ephone-dn 3
number 1030
ephone-dn 4
number 1040
ephone-dn 5
number 1050
ephone-dn 6
number 1060
ephone 1
device-security-mode none
mac-address 0090.21C9.C0B1
type 7960
button 1:1
ephone 2
mac-address 0007.EC1A.23C7
type 7960
button 1:2
ephone 3
mac-address 00E0.B0DD.C78C
type 7960
button 1:3
ephone 4
mac-address 00D0.97B0.57E2
type 7960
button 1:4
ephone 5
mac-address 00E0.B095.AC39
type 7960
button 1:5
ephone 6
mac-address 000C.CFBE.C189
type 7960
button 1:6
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
do you have a diagram of your topology showing how the devices are connected ? Is this a Packet Tracer project ? If so, post the zipped project (.pkt) file...
temkintegegn
Here is my topology. Thanks for the help in advance. I used cisco version 8.0
EDGE
VOIP
VOIP#sh run
version 15.1
hostname VOIP
ip dhcp pool vlan8
no ip cef
no ipv6 cef
no ip domain-lookup
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
telephony-service
max-ephones 40
max-dn 144
ephone-dn 1
number 1010
ephone-dn 2
number 1020
ephone-dn 3
number 1030
ephone-dn 4
number 1040
ephone-dn 5
number 1050
ephone-dn 6
number 1060
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
ephone 3
type 7960
button 1:3
ephone 4
type 7960
button 1:4
ephone 5
type 7960
button 1:5
ephone 6
type 7960
button 1:6
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
