Help with GRE tunneling on loopback interfaces
Hello, I'm creating a network project, I've configured all the routers and end devices, but the traffic isn't going through the tunnel. There's no communication happening at all.
Below I provide the configuration of routers participating in tunneling
13 Replies 13
You need to add
Static route <remote-lan> tunnel-head-ip
This need in both router you config gre tunnel on it.
MHM
I will also add a photo of the network
Ip route command
the tunnel source and tunnel destination and tunnel IP  must include in ACL of IPsec tunnel.
this make the traffic of GRE pass other IPsec
MHM
I understand, but I would like all network traffic to be routed only through the GRE tunnel, between routers A1 and B1. In this case, would I also need an ACL and IPsec tunneling?
No you share the topology and I see IPsec between middle routers
this IPsec use to connect two routers in path between GRE tunnel routers,
you can try remove the crypto map and check
also are the GRE tunnel is UP/UP (show ip interface status)
MHM
Still this issue not solved
I will share lab after football match' it easy for me take 15 min max'
I will share lab with config of each routers
Dont worry
MHM
Do you have underlay routing? As in can your local loopback interface ping your remote loopback interface. Can you please provide the output of the successful ping?
If it doesn't work you will need to establish this for it to work.
-David
I can't ping looback int
You will need to establish connectivity between the loopbacks to continue with your GRE configuration.
Okay I can ping from computers to loopback interfaces. But only to those connected to the same router.
You need to employ either a routing protocol or static routes from your source router to destination router and vice versa. Underlay connectivity is a requirement for tunnel otherwise your devices don't know how to route them.
R5#show running-config
Building configuration...
Current configuration : 2219 bytes
! Last configuration change at 01:41:12 UTC Wed Feb 21 2024
version 15.2
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key mhm address 0.0.0.0
crypto ipsec transform-set mhm esp-des
mode tunnel
crypto map mhm 10 ipsec-isakmp
set peer 110.0.0.3
set transform-set mhm
match address 100
interface FastEthernet0/0
ip address 210.0.0.5 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
ip address 200.0.0.5 255.255.255.0
speed auto
duplex auto
crypto map mhm
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/1
no ip address
shutdown
speed auto
duplex auto
router ospf 100
network 100.0.0.0 0.0.0.255 area 0
network 110.0.0.0 0.0.0.255 area 0
network 200.0.0.0 0.0.0.255 area 0
network 210.0.0.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 permit ip host 6.6.6.6 host 2.2.2.2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
R3#show run
R3#show running-config
Current configuration : 2147 bytes
! Last configuration change at 01:33:15 UTC Wed Feb 21 2024
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
hash md5
mode tunnel
set peer 200.0.0.5
match address 100
ip address 110.0.0.3 255.255.255.0
duplex full
crypto map mhm
no ip address
shutdown
speed auto
duplex auto
ip address 100.0.0.3 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
no ip http server
access-list 100 permit ip host 2.2.2.2 host 6.6.6.6
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#show running-config '
% Invalid input detected at '^' marker.
Current configuration : 1819 bytes
! Last configuration change at 01:38:24 UTC Wed Feb 21 2024
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 110.0.0.4 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 200.0.0.4 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
R2#show run
R2#show running-config
Current configuration : 2019 bytes
! Last configuration change at 01:34:54 UTC Wed Feb 21 2024
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
tunnel source Loopback0
tunnel destination 6.6.6.6
ip address 10.0.0.2 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 100.0.0.2 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
network 2.2.2.2 0.0.0.0 area 0
no ip http server
ip route 20.0.0.0 255.255.255.0 Tunnel0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R6#show run
R6#show running-config
! Last configuration change at 01:36:56 UTC Wed Feb 21 2024
version 15.2
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 6.6.6.6 255.255.255.255
interface Tunnel0
ip address 5.0.0.6 255.255.255.0
tunnel destination 2.2.2.2
ip address 210.0.0.6 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.6 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
network 6.6.6.6 0.0.0.0 area 0
no ip http server
ip route 10.0.0.0 255.255.255.0 Tunnel0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
lab with all commands you need
