Help with IP prefix list
Andrew White
Level 2
Level 2
On our Nexus switches we have a BGP peering with an external company.  I need to advertise our WAN subnet into their BGP and need some help.  They want me to use IP Prefix lists for the below subnets that exist in our WAN.
172.30.0.0/24  (we have about 10 networks /24 here like 172.30.5.0/24 and 172.30.15.0/24)
192.168.138.0/24
192.168.136.0/24
192.168.115.0/24
192.168.144.0/22
192.168.3.0/24
This external company need to get to the above subnets and visa versa.  BGP is working already by the way.
Is it best to use an access list or route map?
Would this work?
ip prefix-list myprefixlist1 seq 5 permit 172.30.0.0/24 ge 23 le 25
ip prefix-list myprefixlist1 seq 10 permit 192.168.138.0/24
ip prefix-list myprefixlist1 seq 15 permit 192.168.136.0/24
ip prefix-list myprefixlist1 seq 20 permit 192.168.115.0/24
ip prefix-list myprefixlist1 seq 25 permit 192.168.144.0/22
ip prefix-list myprefixlist1 seq 30 permit 192.168.3.0/24
router bgp 65000
neighbor 192.0.2.2 remote-as 65001
neighbor 192.0.2.2 prefix-list myprefixlist1 in
"Wouldn't ip prefix-list myprefixlist1 seq 5 permit 172.30.0.0/24 ge 23 le 25 cover all subnets in 172.30.x.x/24?"
It would be:
ip prefix-list myprefixlist1 seq 5 permit 172.30.0.0/16 ge 23 le 25
"I guess I could just do?
That would match exactly the 172.30.0.0/24 and nothing else.
or
172.30.0.0/19 ge 24 le 24 as this will allow 172.30.0.x/24-172.30.31.x/24 subnets"
Sounds good to me :)
Cheers.
7 Replies 7
Martin L
permit 172.30.0.0/24 ge 23 le 25 looks wrong... .give me a second... i take a deep look
I have the range start from 172.30.1.x/24 , but have some on 172.30.3.x/24 then 7.x/24, 14,x/24, 21.x/24 and so on up until 31.x/24.  They are in no sequential order.
or
It would be:
or
Cheers.
I think "ip prefix-list myprefixlist1 seq 5 permit 172.30.0.0/24" is the same as "ip prefix-list myprefixlist1 seq 5 permit 172.30.0.0/24 ge 23 le 25"
Both statements would cover subnets 172.30.0.0/24 to 172.30.255.0/24 is that correct?
permit 172.30.0.0/24 ge 23 le 25 --is invalid due to length of /24; make sure: specified length < ge-value <= le-value, that's why Hector used /16 and not /24
1st part is match my network bits. aka 24 bits in 172.30.0.0, so last octet does not matter what u got.
then, match mark prefix length /23, /24,and /25 inclusive
see https://learningnetwork.cisco.com/message/727879#727879
Martin L
your prefix should be 172.30.0.0/20 ge 24 le 24
- 172.30.0.0 255.255.240.0 give u range of 172.30.0.1 to 172.30.15.254 (magic number 16)
- ge 24 le 24 is needed to mark prefix length, which is /24 exact
Furthermore, if u want to eliminate 1st 4 prefixes, 172.30.0.0/24 thru 172.30.4.0/24 since you have 172.30.5.0/24 thru 10.0
you can add deny before permitting 172.30.5.0/20
deny 172.30.0.0/22 ge 24 le 24
permit 172.30.5.0/20 ge 24 le 24
how to get that or why , see https://learningnetwork.cisco.com/thread/133609?start=0&tstart=0
Please rate and mark posts accordingly if you have found any of the information provided useful.
