1841 Router Readonly ROMMON initialized on every startup
Hi all,
I have recently purchased a CCNA lab for home study and I have noticed that every time I boot up the router, I get a Readonly ROMMON initialized. I have not noticed this message before, so not too sure if this is normal or weather I have messed up the flash while trying to factory reset the router.
Below is the captured bootstrap and Thanks in advanced.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x1df7844
Self decompressing the image : ###########################################
################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X0002 0X0001A800 Card in slot 0
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 17657740 bytes to IO Memory.
PMem allocated: 242221056 bytes; IOMem allocated: 26214400 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ENTBASE-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 04-Aug-11 19:42 by prod_rel_team
Image text-base: 0x60019970, data-base: 0x6270A0A0
Cisco 1841 (revision 7.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ1519C2SL
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
63808K bytes of ATA CompactFlash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
*May 7 23:30:22.459: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to down
*May 7 23:30:23.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
*May 7 23:30:26.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*May 7 23:30:26.655: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*May 7 23:31:07.579: %SYS-5-RESTART: System restarted --
*May 7 23:31:07.587: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*May 7 23:31:08.919: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*May 7 23:31:08.919: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*May 7 23:31:08.919: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to administratively down
Router>
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System image file is "flash:c1841-entbase-mz.150-1.M7.bin"
Last reload type: Normal Reload
License Info:
License UDI:
Device# PID SN
*0 CISCO1841 FCZ1519C2SL
Configuration register is 0x2142
Router#
Spoiler
just to confirn,  Readonly ROMMON initialized is normal on boot up?
This is a normal boot process.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
6 Replies 6
balaji.bandi
Your config registry set to - Configuration register is 0x2142
change the  confreg 0x2102 and reload
BB
Thank you for your prompt reply,
I have set the confreg to 0x2102 and I am still getting the same result.
PLD version 0x10
Self decompressing the image : ##################################################################################################################################################################################### [OK]
ID MEMORY_REQ TYPE
cisco Systems, Inc.
Image text-base: 0x6000F990, data-base: 0x627000C0
*Jun 6 00:43:16.463: %LINK-3-UPDOWN: Interface Serial0/0/0, changed state to down
*Jun 6 00:43:17.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0, changed state to down
*Jun 6 00:43:19.019: %SYS-5-CONFIG_I: Configured from memory by console
*Jun 6 00:43:19.267: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Jun 6 00:43:19.267: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Jun 6 00:43:19.683: %SYS-5-RESTART: System restarted --
*Jun 6 00:43:19.687: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Jun 6 00:43:20.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Jun 6 00:43:20.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Jun 6 00:43:20.967: %LINK-5-CHANGED: Interface Serial0/0/0, changed state to administratively down
Router>
Router>show ver
Router>show version
Router uptime is 1 minute
License Info:
License UDI:
Device# PID SN
Router>
I was looked only your config register before - when i read last time.
if you looking below message as error -  Readonly ROMMON initialized - i believe this is normal.
BB
Hi Balaji,
Sorry was away on vacation, i belive it is correct understanding.
BB
Spoiler
Deepak Kumar,
