Help with lab simulaton MPLS failover to IPSec tunnel
news2010a
Level 3
Level 3
I want to build a simple lab wth 4 routers showing the following:
Router1CE----MPLS-----Router2CE
Router2BackUp----Internet---IPsec tunnel -----Router2Backup
I have the core MPLS network OK.
Goal:
In case Router1CE or MPLS fails, I want all the traffic to flow thru Router2Backup---Internet and reach the MPLS network thru Router2CE. I would reach teh MPLS network because in the production network I have SIP trunking running and also other 3 sites overseas.
Is there any sample showing or can you please just tell me if you would normally configure HSRP or give me some hints to get this done.
meperuma
You can do it few ways depend on your current network design
Hsrp with object tracking
Use ipsla to track the icmp reply and use eem to take actions
