Need help to configure a router as a terminal server with reverse telnet
Hi all,
I would like to know if someone has an example of router config for a terminal server.
In fact I need a configuration for a router with multiple, low speed, asynchronous ports that are connected to other serial devices, for example,
modems or console ports on routers or switches.
With this router I would like to use a reverse telnet to connect with my devices using the serial connection.
I find many examples on the Cisco web site but none with my router hardware configuration.
My router is a 3620 router with a 8 port async (NM-8A/S) network module and I would like to use the 8 serial interfaces, each of them connecting a serial device.
Thank you by advance.
Here is the show run and show ver :
Router#show ver
IOS (tm) 3600 Software (C3620-I-M), Version 12.3(25), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 28-Jan-08 20:16 by alnguyen
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System returned to ROM by reload
System image file is "flash:c3620-i-mz.123-25.bin"
cisco 3620 (R4700) processor (revision 0x81) with 45056K/4096K bytes of memory.
Processor board ID 11876590
R4700 CPU at 80MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
12288K bytes of processor board System flash (Read/Write)
Router#show run
Building configuration...
Current configuration : 883 bytes
version 12.3
hostname Router
boot-start-marker
boot system flash flash:c3620-i-mz.123-25.bin
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface Ethernet0/0
ip address dhcp
half-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
skarthic
The below mentioned link explains on how to configure a router as terminal server. I have used this config
earlier to set up my lab.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Config details:
ip host 3600-2 2013 172.21.1.1
ip host 5200-1 2010 172.21.1.1
ip host 2600-1 2008 172.21.1.1
2013,2010,2008 are the terminal port lines in which you get connected to the router...
Also rememer that 2013 corresponds to the 13th serial port in the router.
While you want to "3600-2" device connected in the 13th serial port use "telnet host [port]           [keyword]"
(ie) telnet 172.21.1.1 2013
Remember in order to reverse telnet the port no should be 2000+serial port no
