I am getting the following message on boot up of a PXM45/C card
* This CARD NVRAM is not programmed correctly
* Program the NVRAM using the DIAG image ASAP
* System WILL NOT come up if this continues
* Front Card  STATUS: UNKNOWN
* Bot Bay BC STATUS: OK
When I run the command dspcdhealth on the card I get the following:
Unknown.8.PXM.if > dspcdhealth 8
* PXM Failed for the following reasons:
*     Fail                         Recovery
*     Reason                       Method
* 1.  FC NVRAM Read Fail       Program FC NVRAM or Replace FC
* 2.  Disk Not Synch           shellConn cmd: shmRecoverClrallcnf
Unknown.8.PXM.if >
clearing the config does nothing.
So here is my question, how in the world do I program the FC NVRAM on this card?
