Help with routing
Louis1984
Community Member
Hi guys
I'm struggling with packet tracer on an exercise and have not been able to identify why the router can not route traffic to a second wireless router
Unfortunately I'm not allowed to attach a packet tracer file here
Background info:
PC-PT 192.168.1.1
WRT300N Wireless Router 192.168.1.254 (public IP 147.8.1.1)
ISP Router FA0/0 147.8.1.254
IS Router FA1/0 203.1.2.254
Webserver 203.1.2.100
In short it is
PC --> Wireless Router 1 --> ISP Router --> Webserver
At this stage, I'm able to ping the webserver 203.1.2.100 and also access the webpage of 203.1.2.100
What needs to happen is
PC --> Wireless Router 1--> ISP Router --> Wireless Router 2 --> 2 Webservers
The wireless router 2 & the 2 web servers is a company. They have only 1 public IP which is 203.1.2.100, so port forwarding should be used, so when ever users access port 80 on 203.1.2.100 goes to webserver 1, and when they use port 443 on 203.1.2.100 it goes to webserver 2.
I have played around for 5 hours, and can't get past the 2nd wireless router issue. The moment I add the second wireless router, i can no longer ping to the 2nd wireless router from the pc. All other hops "before" the wireless router works perfectly. I'm at a dead end and don't know anymore what I'm doing wrong.
Note: Before adding the 2nd wireless router, everything works. So I am pretty sure that the settings on the PC, Wireless Router 1 and ISP router are correct. I was able to ping the webserver. But as soon as I include a 2nd wireless router behind the ISP router, it all goes bad. I can ping from PC to Wirelss Router 1, from PC to ISP Router FA0/0 and FA1/0, but can not get further than that. So for some reason the ISP router does not route my package to the 2nd wireless router or even further.
I would certainly appreciate some help here guys. If need be, I can send the packet tracer file to you
Some info from the ISP router:
Router>show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
C 147.8.0.0/16 is directly connected, FastEthernet0/0
C 203.1.2.0/24 is directly connected, FastEthernet1/0
Router>show ip protocol
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 17 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Redistributing: rip
Default version control: send version 1, receive any version
Interface Send Recv Triggered RIP Key-chain
FastEthernet0/0 1 2 1
Automatic network summarization is in effect
Maximum path: 4
Routing for Networks:
147.8.0.0
Passive Interface(s):
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 120)
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
 ip address 147.8.1.254 255.255.0.0
 duplex auto
 speed auto
interface FastEthernet1/0
 ip address 203.1.2.254 255.255.255.0
 duplex auto
 speed auto
interface Serial2/0
 no ip address
 clock rate 2000000
 shutdown
interface Serial3/0
 no ip address
 clock rate 2000000
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
router rip
 network 147.8.0.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Julio E. Moisa
Have you tried enabling Rip version 2 on all the routers?
configure terminal
router rip
version 2
network 0.0.0.0 <--- you could configure this line to test connectivity and probably any network is missed.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
@Louis1984 wrote:
Hi guys
Background info:
PC-PT 192.168.1.1
In short it is
If this was working before you introduced the wifi 2 rtr obviosuly you need to be looking at that device intrems of its configuration and it relation to the ISP.
What i am not so sure on is where does this Wifi2 rtr reside, if now its infront the of webserver which it has to be then what was allowing access to the webserver before wiif 2 introduction?
Can you please clarify this.
res
Paul
It seems you have nat enabled on wifi1 rtr already for the PC lan subnet
Kind Regards
Paul
