11-15-2010 09:13 AM - edited 03-04-2019 10:28 AM
Customer has older 2950s in multiple closets. Wants to expand and needs POE as
part of the new switche features. Will the 2950's stack with the 3750's and still allow for management from a si
ngle console?
11-15-2010 11:39 AM
The 2950's do not support stacking so the answer would be no.
Hope it helps.
11-15-2010 09:03 PM
Like Colin said, stacking is not supported on 2950s. You can look into clustering -
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swclus.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swclus.html
Log in to Community
