Help...
arjunsawant
Hi...
I cleared CCNP.
Can i give Security Cisco ASA exam directly.
Thanx....
Peter_Kurdziel
For Cisco ASA Specialist you need to take and pass 642-524 SNAF & 642-515 SNAA.
See http://cisco.com/web/learning/le3/le2/le0/le5/learning_certification_type_home.html for more info.
Hi..
Thanx for your kind reply..
I want to give 642-524 (CCSP).
Is it possible?
Thanx once again.
Hi Arjun,
The primary requirement for any CCSP exam is have a CCNA Security or CCNA + SND(Till November 17, 2011) certification.
If you have any of the certification above you can give the 642-524 (SNAF) exam.
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
Thanx.....a lot.
