Helping a Church out with some IT work
stonnet72
Here is the scenario:
Church has the following:
LAN--> 3 Switches --> DSL for Data connection
Phones --> VOIP --> Switch --> T1
The phone system is setup as VOIP through a T1. There data services (internet connection) is going through a DSL. The church director wants to use the T1 for data services as well and make the DSL a backup, so T1 x (VOIP and Data) = Primary and DSL x (data ONLY) = secondary.
1. Is this possible (I imagine this is via some advanced routing configuration)
2. Does anyone know of a starter config that I can use to mimick the configuration for this router (2621XM router with two configurable ports)
Thanks guys. I really appreciate the help. I am familiar with configuring the router but, not so sure about setting up the primary and secondary data connections.If I am close to the answer, I think it will just be a matter of setting up a subinterface...I am not sure though
belovell
If you know the destination of your VoIP traffic(i.e. it all goes through your VoIP provider at IP address x.x.x.x) them this can be done fairly simplely with three routesand an ACL
ip route 0.0.0.0 0.0.0.0 <== primary default route
ip route 0.0.0.0 0.0.0.0 250 <=== backup default route. Will only com into play if T1 link goes down
ip route x.x.x.x x.x.x.x <== voice route.
ip access-list 101 deny ip
ip access-list 101 permit ip any any
ACL will block all voice traffic that tries to exit DSL interface.
-Ben
