High Bandwidth Utilization
bhisham Sharma
Community Member
Hi All,
I am facing issue in my Domestic MPLS, let me explain below.
we have 2 sites in different states connected with MPLS with 45Mbps b/w capacity, Internet gateway is flowing like from Site A to Site B on MPLS then Internet link on site B. i have run prtg to see b/w utilization and there are lot spikes in it, i saw ip flow top-talkers on both sites routers and can see one destination which we have allowed for some users to download some data from client ftp in Gbs.
My question is this the only reason of the spikes? i have 45 B/w capacity i think its enough. If this the only reason then can any body suggest any option by which i can specify some part of b/w to this only via rate-limit or by any other method will that work?
below is the output of ip flow top-talker
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP Bytes
Gi0/0         209.x.x.51    Gi0/1         10.x.x.50    06 0016 ED6F   100M
Gi0/0         209.x.x.51    Gi0/1         10.x.x.77    06 0016 C0E7    60M
Gi0/0         209.x.x.51    Gi0/1         10.x.x.50    06 0016 ED8B    50M
Gi0/0         209.x.x.51    Gi0/1         10.x.x.50    06 0016 ED6E    24M
Gi0/0         10.x.x.115    Gi0/1         10.x.x.52    06 F2B7 043C    15M
Gi0/0         10.x.x.6      Gi0/1         10.x.x.222   06 1F90 0425  9873K
Gi0/0         209.x.x.51    Gi0/1         10.x.x.50    06 0016 ED8A  7811K
Gi0/0         10.x.x.6      Gi0/1         10.x.x.204   06 1F90 0420  7190K
Gi0/0         172.x.x.5     Gi0/1         10.x.x.152   11 D522 270C  5821K
Gi0/0         10.x.x.6      Gi0/1         10.x.x.202   06 1F90 049E  5633K
Gi0/0         209.x.x.51    Gi0/1         10.x.x.83    06 0016 0691  5381K
Gi0/0         209.x.x.51    Gi0/1         10.x.x.50    06 0016 EDA6  5375K
Gi0/1         10.x.x.45     Gi0/0         10.x.x.77     11 6824 C9AC  5332K
Gi0/1         10.x.x.45     Gi0/0*        10.x.x.77     11 6824 C9AC  5332K
Gi0/1         10.x.x.142    Gi0/0         10.x.x.121    11 0A8C 0A84  5332K
Gi0/1         10.x.x.142    Gi0/0*        10.x.x.121    11 0A8C 0A84  5332K
Gi0/0         10.x.x.77     Gi0/1         10.x.x.45     11 C9AC 6824  5331K
Gi0/0         10.x.x.6      Gi0/1         10.x.x.211    06 1F90 0428  4871K
Gi0/0         10.x.x.17     Gi0/1         10.x.x.77     06 01BD C39B  3864K
Gi0/0         209.x.x.51    Gi0/1         10.x.x.77     06 0016 C0E5  3856K
Gi0/0         209.x.x.51    Gi0/1         10.x.x.83     06 0016 0690  3772K
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Insufficient information.
Rate-limiting (or policing) is probably a possible method to restrict bandwidth utilization, but unclear there's a need to do so.  Additionally, if bandwidth consumption is from an Internet site, rate-limiting it will be downstream of the Internet link, so it can be less than ideal.  Across the MPLS link, if you control both sides egress, there might be many things you could do.
A bandwidth utilization graph, with spikes or not, tells you very little, by itself, about bandwidth needs.  It's sort of like if I graphed your pulse rate.  It too would likely have highs and low, spikes too, but if that's all I know it tells me little (other than your heart is beating).
Thanks Joseph!!
"Across the MPLS link, if you control both sides egress, there might be many things you could do"
I have access to both sites, could plese let me know what other things i can do.
People at site A download data from Client FTP in GBs on daily basis via Internet link which in Site B, that's why MPLS link connecting both sites having spikes.This is the main reason.
I am attaching graph where you can see spikes,
Disclaimer
Posting
For your MPLS links, if your hardware supports it, and if you're only using FIFO queuing, I would recommend using a CBWFQ policy with default class defined and with fair-queue enabled, i.e.:
policy-map SampleOut
class class-default
fair-queue
interface (T3)
service-policy output SampleOut
Such a policy often mitigates the adverse impact of a high-volume flow against other low-volume flows.
If your MPLS has multipoint, i.e. more than one other possible router can send to your receiving router, you may want to investigate the QoS options supported by your MPLS vendor (if any).
For your Internet link, what you can do effectively, is curtailed, if you can't directly manage traffic toward you.  However, you can rate-limit specific traffic to specific rates, for example:
class-map match-any bulkTraffic
match protocol ftp
policy-map SampleLimitIn
class bulkTraffic
police average #
Interface (Internet)
service-policy in SampleLimitIn
Hi Joseph,
Thanks a lot!!
I am not confident enough in Qos so attaching config of my & ISP managed routers & attached one rough diagram to make you understabd the setup, could you please see and let me knwo what can i do to stop those spikes and to reserve some b/w for that particular destination.
All config are from Site A only.
It would be great help for me thanks.
My Managed Router:-
class-map match-any business
match access-group name business_critical
class-map match-any Exch-Rate-Limit
match access-group name Exch-Rate-Limit
class-map match-any Rate-Limit-Test
match access-group name Rate-Limit-Test
class-map match-any non-business
match access-group name non-critical
class-map match-any premium
match access-group name interactive_video_or_voice
policy-map parent-test
class premium
  set ip dscp ef
  priority percent 20
class business
  set ip dscp default
  bandwidth remaining percent 60
class non-business
  bandwidth remaining percent 30
class class-default
policy-map MPLS-TATA
class class-default
  shape average 46080000
  service-policy parent-test
policy-map Exch-Rate-Limit-Policy
class Exch-Rate-Limit
   police cir 4096000 bc 1024000 be 1024000
policy-map Rate-Limit-Test-Policy
class Rate-Limit-Test
   police cir 3145500 bc 1024000 be 1024000
interface GigabitEthernet0/0
description << Connected to TCL primary on X over g0/1>>
ip address 172.x.x.2 255.255.255.252
ip access-group Security_tata_mpls in
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip flow ingress
ip flow egress
ip route-cache flow
ip summary-address eigrp 17XXX 10.x.x.0 255.255.224.0 5
load-interval 60
duplex full
speed 100
no cdp enable
service-policy output MPLS-TATA
interface GigabitEthernet0/1
description << Connected to LAN >>
ip address 10.x.x.131 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
load-interval 30
duplex full
speed 100
service-policy input Exch-Rate-Limit-Policy
service-policy output Rate-Limit-Test-Policy
router eigrp 17xxx
redistribute eigrp 33xx route-map advertiselan
passive-interface default
no passive-interface GigabitEthernet0/0
network 172.x.x.0 0.0.0.3
no auto-summary
no eigrp log-neighbor-changes
router eigrp 33xx
redistribute eigrp 17xxx route-map advertisempls
no passive-interface GigabitEthernet0/1
network 10.x.x.0 0.0.31.255
distribute-list mpls_to_lan out GigabitEthernet0/1
distribute-list lan_to_mpls in GigabitEthernet0/1
no auto-summary
route-map advertiselan deny 5
match tag 4755124
route-map advertiselan permit 10
match ip address lan_to_mpls
route-map advertisempls permit 10
match ip address mpls_to_lan
set tag 4755124
ISP managed Router:
match ip dscp default
class-map match-all Rate-Limit-Test
class-map match-all Exch-Rate-Limit
match any
class-map match-any ABC_C2_WAN
class-map match-any ABC_C1_WAN
match ip dscp ef
match ip dscp ef
policy-map parent
class premium
  priority percent 20
class business
class class-default
policy-map ABC_30Mb_WAN_Child_Out
class ABC_C1_WAN
  priority 6144
class ABC_C2_WAN
  bandwidth 18432
class class-default
policy-map ABC_45Mb_WAN_Child_Out
class ABC_C1_WAN
  priority 9216
class ABC_C2_WAN
  bandwidth 27648
class class-default
policy-map ABC_45Mb_WAN_Parent_Out
class class-default
  service-policy ABC_45Mb_WAN_Child_Out
policy-map ABC_30Mb_WAN_Parent_Out
class class-default
  shape average 30720000
  service-policy ABC_30Mb_WAN_Child_Out
interface Loopback0
description *** MGMT ***
ip address 10.x.x.151 255.255.255.255
interface Tunnel100
description TUNNEL to XXX
ip address 1.x.x.2 255.255.255.252
tunnel source 10.x.x.18
tunnel destination 10.x.x.14
tunnel mode ipip
description **** XXX WAN ***
bandwidth 46080
ip address 10.X.X.18 255.255.255.252
load-interval 30
delay 10
duplex full
speed 100
service-policy output ABC_45Mb_WAN_Parent_Out
description << Connected to ABC LAN >>
ip address 172.X.X.1 255.255.255.252
load-interval 30
duplex full
speed 100
router eigrp 17xxx
network 10.x.x.16 0.0.0.3
no auto-summary
i
route-map SET_TAG_TCL permit 10
set tag 4755124
route-map MATCH_TAG deny 5
match tag 4755124
route-map MATCH_TAG permit 10
match ip address ExceptGGN
