04-17-2014 08:38 AM - edited 03-04-2019 10:48 PM
i have an issue i can't quite figure it out, i pretty sure its related to the encryption tunnels im using but im not sure why.
I have a couple of 2911 connected together over a direct ipsec tunnel that is running 70+ mbs of encrypted traffic. Looking at the CPU, im seeing about 90% used due to interrupts. Now i do have an ISM VPN card which from what i understand is supposed to take care of encryption and leaving the main CPU free for other tasks. From what i looked at so far everything looks good, CEF is working fine etc.
My question is why is my CPU so high what can i do to fix the situation. I'm at a loss here as to why the cpu is running so high and im almost 100% is related to the encrypted ipsec tunnel traffic but shouldn't the integrated VPN module be doing all the work. If anyone has some pointers its greatly appreciated.
gw#sh ip cef switching statistics
Reason Drop Punt Punt2Host
RP LES No route 63 0 1
RP LES Packet destined for us 0 1393320 51367
RP LES TTL expired 0 0 486678
RP LES Fragmentation failed, DF 3014276 0 0
RP LES Discard 72653 0 0
RP LES Features 4157 0 31435
RP LES Fragmentation no pak 0 0 764
RP LES Total 3091149 1393320 570245
All Total 3091149 1393320 570245
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 410484 725275 565 0.00% 0.04% 0.01% 0 Load Meter
6 15344596 922323 16636 0.00% 0.04% 0.05% 0 Check heaps
13 25190192 60005 419836 0.00% 0.07% 0.10% 0 Licensing Auto U
14 15439912 3584474 4307 0.00% 0.08% 0.06% 0 Environmental mo
67 1064772 3612958 294 0.07% 0.03% 0.02% 0 Per-Second Jobs
90 612 157 3898 0.00% 0.05% 0.01% 388 Virtual Exec
96 936256 7203871 129 0.00% 0.03% 0.02% 0 BPSM stat Proces
98 250836 22404658 11 0.07% 0.00% 0.00% 0 Ethernet Timer C
99 3526716 345916589 10 0.15% 0.15% 0.15% 0 Ethernet Msec Ti
125 810144 97403729 8 0.00% 0.03% 0.02% 0 IPAM Manager
129 359592 1973843 182 0.00% 0.01% 0.00% 0 IP Input
311 5578200 615440929 9 0.23% 0.27% 0.27% 0 IP SLAs XOS Even
interface Tunnel1
bandwidth 100000
ip unnumbered GigabitEthernet0/1
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1398
load-interval 30
tunnel source GigabitEthernet0/1
tunnel mode ipsec ipv4
tunnel destination 172.17.2.5
tunnel path-mtu-discovery
tunnel protection ipsec profile ipsec_profile_to_hq
end
Tunnel protocol/transport IPSEC/IP
Tunnel TTL 255
Path MTU Discovery, ager 10 mins, min MTU 92
Tunnel transport MTU 1438 bytes
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Tunnel protection via IPSec (profile "VTI-NB")
Last input never, output never, output hang never
Last clearing of "show interface" counters 5w2d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 16072
Queueing strategy: fifo
Output queue: 0/0 (size/max)
30 second input rate 1795000 bits/sec, 3195 packets/sec
30 second output rate 71052000 bits/sec, 6012 packets/sec
thanks for taking your time,
paul
Solved! Go to Solution.
04-17-2014 06:14 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My understanding is, mss-adjust does not set IP MTU, your path-mtu-discovery should have set it.
Cisco's recommendation to set mss-adjust to 1360 (and IP MTU to 1400) are rather conservative. It's a little more efficient to go larger, but more important is avoiding fragmentation.
Also Cisco's recommendation also assumes MSS is MTU less 40; which it normally is, but again, IP or TCP options will decrease MSS relative to MTU.
Overall, I suspect you're just bumping up against the 2911's maximum performance (that's one of the reasons why there's a 2921 and 2951, and the other "faster" ISRs).
04-17-2014 10:39 AM
Disclaimer
Posting
The encryption hardware does just that, encryption and decryption; everything else is still left to the main CPU, and there's more to do when supporting encrypted traffic.
In the Cisco's whitepaper I've attached, Table 7 notes a 2911 with 61 Mbps of (aggregated) encrypted traffic at 75% CPU utilization. So your 90% at 70+ Mbps, doesn't seem way out of line. (NB: Other features also add to CPU loading, such as your NAT. See Table 6 for PAT performance. Also note performance delta between Tables 6 and 7.)
In your config, one interface statement that might help is IP MTU. You have MTU discovery enabled, which is good, but it will keep discovering that you're unable to send full size (standard) Ethernet packets. IP MTU sets a new cap, and then MTU discovery only should trigger if an upstream path forces the MTU even smaller.
Even with IP MTU, tcp mss-adjust and path-mtu-discovery, non-TCP traffic won't be impacted by tcp mss-adjust (nor will existing TCP flows that move to the tunnel) and IP and TCP options require more than the usual 40 difference between mss and the packet's size. Such situations can cause traffic to be fragmented.
So, again, your CPU utilization, for your specific traffic, might be "normal".
Lastly, I recall (?) seeing some posts where virtual-reassembly is unnecessary, but adds to CPU loading.
04-17-2014 12:32 PM
1st off thanks Joseph for the response, I will read that white paper shortly. Just a quick question what should of set the IP MTU 1438? - right now the tunnel shows, Tunnel transport MTU 1438 bytes. I didn't hardcode that command because the correct MTU is set by default taking into account the MSS i setup manually of 1398. Do you recommend i set the mss to the cisco recommendation 1360, i really dont want to make things worst and end up with fragments. I will look into the ip reassembly and see if that makes a difference.
if this is normal ISR ipsec cpu behavior this kind of sucks, especially now that i just found out the encryption limit is 85kbps which im already hitting at times.
thanks, paul
04-17-2014 06:14 PM
Disclaimer
Posting
04-18-2014 12:34 PM
Joseph, i agree with you after reading the whitepaper it looks like a router capacity limit issue :(. this whole thing opened my eyes to how underpowered the 2911 for large encryption branches. im using MSS of 1398 which so far is working great, I took into account 40 bytes for ip/tcp and 62 for ipsec via VTI. I probably should go lower because of options but so far so good. also it looks like when using VTI ipsec tunnel it automatically adjusts the MTU with or without mtu path discovery or adjust-mss. However if i didnt have the adjust-mss i was getting lots of fragment packets because MSS was being adjusted as if the tunnel was 1500 MTU.
thanks, Paul
