High CPU utilization and memory utilization issue
knaik99
Level 5
Level 5
1.Reason that we see High CPU utilization issue for router and switches.
commands --SH process cpu ? like that right?
2.Reason that we see High memory utilization issue for router and switches.
here when we see High memory Utilization issue then is it related to Flash or any other memory? Please explain.
command --show platform resources ? right?
7 Replies 7
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
           https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/6507-mallocfail.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
What platform(s)?
Joseph W. Doherty
For both high CPU and/or high memory utilization, for both routers and/or switches, sometimes cause is completely normal, for example, as a software based router uses its CPU to forward traffic, CPU utilization will increase/decrease with traffic volume, sometimes cause is due to "unusual" traffic or "unusual" network issues, and sometimes you've bumped into some form of "software defect" (a bug).
@Mark Elsen has provided links to help investigate cause of high CPU and/or high memory usage.
@Leo Laohoo's question about the platform is likely due to his knowledge of many common bugs that cause such issues.
knaik99
Level 5
Level 5
Memory means flash or which one when we have full memory issue?
RAM not flash.
What is difference between DRAM and NVRAM
DRAM is volatile, NVRAM is not.  I.e. DRAM loses contents with loss of power.
DRAM generally has much, much (much) faster read/write access than NVRAM.
