High CPU utilization in CISCO2911
Raja_D
We notice high CPU utilization over our CISCO2911 device and our tool reports high cpu alert accordingly.
During this high utilization alert we notice that the SNMP engine process is showing pretty high as can be seen in below output
show processes cpu sorted | ex 0.00
CPU utilization for five seconds: 98%/1%; one minute: 97%; five minutes: 95%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 413  2191807316   168978192      12970 93.25% 93.17% 90.87%   0 SNMP ENGINE
Kindly advise if this process of SNMP ENGINE relates to the SNMP traps which are being sent from branch router to SNMP server ?
what are the steps that could be done to fix this..
James..
Mark Malone
take a look at this link for tshooting snmp high cpu
https://supportforums.cisco.com/document/61366/troubleshooting-high-cpu-snmp-engine-process-ios
and this
http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/7270-ipsnmphighcpu.html#high_cpu_ut
In my case I've high CPU issue but it's not possible to identify the reason.
Anyone can help ?
MY_ROUTER#sh processes cpu sort 5sec | ex 0.00%
CPU utilization for five seconds: 89%/82%; one minute: 92%; five minutes: 86%
  13    35935536      197092     182332  3.70%  0.46%  0.31%   0 Licensing Auto U
182   142933116   133876665       1067  1.10%  1.71%  1.41%   0 IP Input
   6    18390284     1424087      12913  0.55%  0.18%  0.13%   0 Check heaps
  33    40729552   214260582        190  0.39%  0.63%  0.64%   0 ARP Input
  15     8538992     5916093       1443  0.39%  0.07%  0.06%   0 Environmental mo
204     5863400   714025809          8  0.15%  0.29%  0.31%   0 Ethernet Msec Ti
346     2225880    91920010         24  0.07%  0.04%  0.05%   0 MMA DP TIMER
  62        6300         910       6923  0.07%  0.10%  0.10% 388 SSH Process
347     2233736    91920240         24  0.07%  0.05%  0.06%   0 PERFMON ASYNC TI
434     2980260     8460839        352  0.07%  0.05%  0.04%   0 NHRP
127     1657772    12122809        136  0.07%  0.03%  0.02%   0 BPSM stat Proces
227     9436492     5934773       1590  0.07%  0.12%  0.13%   0 ADJ background
327     2247448    91920161         24  0.07%  0.05%  0.07%   0 MMA DB TIME
Hi, i have the same problem.
Did you find root cause?
For rafafilho1's post, high CPU appears to be mostly interrupt which normally just implies enough traffic to load up the CPU.
