High cpu utilization on 2611 router during snmp polling
cisco__kaushik
Level 4
Level 4
The cisco 2611 router is experiencing high cpu utilization during snmp polling . The snmp configuration is given below , the router is running a GD release .
snmp-server engineID local 00000009020000024B0E6600
snmp-server community <removed> RO 30
snmp-server community <removed> RW 30
snmp-server location 1.1.1.1
snmp-server enable traps tty
Pl suggest how to reduce the cpu utilization
jwdoherty
Patient: "Doctor, doctor, it hurts when I do this."
Doctor: "Well don't do that."
Some truth to the (old) joke. If you SNMP poll, the router needs to use CPU cycles to respond. There's not much you can change on the router that will reduce SNMP CPU (except perhaps on traps/informs). However, there's much you might change on the external SNMP requestor. Items such as polling frequency, what's being polled, and sometimes even how it's being polled, can be most important.
A different but perhaps more important question is, is the high SNMP CPU utilization adverse to the router's primary functioning? Assuming there's ample CPU to service all processing, a 100% busy CPU, alone, might not be an issue.
