7613 Feature
WE want to Know that Is there 7613 Router support Voice Interface statnderd or not ? is there any extra card require for that ??
Voice Interface Statnderd :-
DSP Features
Codec
G.711 , G.729.. etc.
CCS signaling -Q.SIG, R2 Signaling.
etc........
Laurent Aubert
The following LC are available for 6500 only:
-WS-SVC-CMM-24FXS-24-Port FXS Interface Port Adapter
-WS-SVC-CMM-ACT: Adhoc Conferencing and Transcoding Port Adapter
-WS-SVC-CMM-6T1: 6 Port T1 Interface Port Adapter
-WS-SVC-CMM-6E1: 6 Port E1 Interface Port Adapter
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xy/archive/gtcmm.html
7600 supports it with 12.2SXF but not with 12.2SR
Laurent.
thanks for Reply but i think you tell me that it support IOS 12.2SXF ok..
we are having IOS
s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD6.
Is it support in this version??
Note the indicated modules are for use with callmanager only, do not support E1 R2, etc.
You're better getting a standalone ISR router for voice.
