High CPU Utilization on 7200-VXR with NPEG2
sabuz_banik
My router is running with BGP (One eBGP and One IBGP session). I have filterdown the BGP roting table by using prefix-List and default route to upstream router.But still found the CPU process is high (80%/80% with 60MB traffic). Find the bellow out put and assist me.
Sh Proc CPU
CPU utilization for five seconds: 88%/88%; one minute: 87%; five minutes: 87%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   2         180        4759         37  0.07%  0.06%  0.07%   0 Load Meter
141         240     5936995          0  0.15%  0.15%  0.15%   0 HQF Shaper Backg
Sh Version
KAYSGR1#sh version
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(24)T5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 04-Mar-11 07:11 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE SOFTWARE (fc1)
KAYSGR1 uptime is 6 hours, 37 minutes
System returned to ROM by reload at 04:55:20 UTC Sat Dec 1 2012
System image file is "disk2:c7200p-advipservicesk9-mz.124-24.T5.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 21288417
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.0
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 300 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
1 Packet over SONET interface
2045K bytes of NVRAM.
254464K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
5 Replies 5
Raju Sekharan
Your High CPU is not due to any process. It is because of interupts
Interrupt cpu normally due to traffic switching.
Check the following outputs
Show interfaces | inc up|rate|drop
Show interface stat
Thank you
Raju
Hi Rajs,
I could see droping in my POS1/0 port.
KAYSGR1#sh int | in up|rate|drop
GigabitEthernet0/1 is up, line protocol is up
  Full-duplex, 1000Mb/s, link type is force-up, media type is LX
  output flow-control is XON, input flow-control is unsupported
  Input queue: 0/75/0/660 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  5 minute input rate 64871000 bits/sec, 95991 packets/sec
  5 minute output rate 71232000 bits/sec, 106673 packets/sec
     0 unknown protocol drops
  Full-duplex, 100Mb/s
GigabitEthernet0/2 is up, line protocol is up
  5 minute input rate 2000 bits/sec, 5 packets/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     823 unknown protocol drops
POS1/0 is up, line protocol is up
  Input queue: 0/75/0/738 (size/max/drops/flushes); Total output drops: 1031
  5 minute input rate 62796000 bits/sec, 106805 packets/sec
  5 minute output rate 57215000 bits/sec, 96077 packets/sec
Loopback0 is up, line protocol is up
Sh int stat
KAYSGR1#sh int stats
GigabitEthernet0/1
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor     754223   80812128     843013   81277297
             Route cache 1046381403 1167213846 1205612468 2755282718
                   Total 1047135626 1248025974 1206455481 2836560015
Interface FastEthernet0/2 is disabled
GigabitEthernet0/2
               Processor     116319    7137306       5712     468269
             Route cache       9555     763076       9341    2833799
                   Total     125874    7900382      15053    3302068
GigabitEthernet0/3
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
POS1/0
               Processor     777943   68481332     691191   59953778
             Route cache 1205816136 3599364353 1046535591 3455245224
                   Total 1206594079 3667845685 1047226782 3515199002
Loopback0
               Processor          0          0          0          0
             Route cache          0          0          0          0
                   Total          0          0          0          0
KAYSGR1#
7200 is a CEF router.
It's CPU utilization will go high if the traffic rate goes up. This is expected becasue it uses CPU to switch the traffic
You can also check on your interface configs to see if there is any other features like GRE, QOS, ACL which can furhter add to the CPU
Thank you
Raju
Hi Rajs,
Yes,  but CPU consumption is 80/90% with 60/70MB Traffic is very unlikely.No we are not using QOS, GRE but we are using Prefix-List to bringdown the BGP table.We thought it because of full BGP table and recently deploy this Prefix-list with default route but problem remain same.Please see my Sh run
Sh run
Building configuration...
Current configuration : 2224 bytes
upgrade fpd auto
version 12.4
hostname KAYSGR1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
ip name-server 165.21.100.88
no ipv6 cef
username ---- privilege 15 secret 5 $1$rEK6$0TCQJ/v4WPTjYnXACPxTu/
archive
log config
  hidekeys
interface Loopback0
ip address 10.10.12.12 255.255.255.255
interface GigabitEthernet0/1
description Connect To NetroNext ISP
ip address X.X.X.X  255.255.255.252
duplex auto
speed 1000
media-type sfp
no negotiation auto
interface FastEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description Connect to Kay SG LAN
ip address X.X.X.X 255.255.255.240
duplex auto
speed 1000
media-type sfp
no negotiation auto
interface GigabitEthernet0/3
no ip address
duplex full
speed 1000
media-type sfp
no negotiation auto
interface POS1/0
description Connect To IPLC
crc 32
clock source internal
pos framing sdh
pos scramble-atm
router ospf 100
log-adjacency-changes
network 10.10.12.12 0.0.0.0 area 0
network X.X.X.X 0.0.0.3 area 0
router bgp XXXX
no synchronization
bgp router-id X.X.X.X
bgp log-neighbor-changes
network X.X.X.X mask 255.255.254.0
neighbor 10.10.13.13 remote-as 2.1248
neighbor 10.10.13.13 update-source Loopback0
neighbor 10.10.13.13 next-hop-self
neighbor 10.10.13.13 default-originate
neighbor X.X.X.X remote-as 2.1265
neighbor X.X.X.X update-source GigabitEthernet0/1
neighbor X.X.X.X prefix-list ktel-PL in
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route X.X.X.X 255.255.254.0 Null0
no ip http server
no ip http secure-server
ip prefix-list ktel-PL seq 5 deny 0.0.0.0/0 le 32
snmp-server community XX RO
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
end
KAYSGR1#
elepon06
Generate the following:
1.) Sh Proc CPU hist
2.) complete "Sh Proc CPU"
My suspect is the SNMP process causing it.
