High CPU utilization on ISR1113
Jerems
Hi dear community,
Can you please help me in pointing out what's happening with both ISR1113 (installed at customer premises) and the CPU Cores 2 & 3:
As a reminder, Cores 0 & 1 are dedicated to control plane, cores 2 & 3 are dedicated to data plane.
"show proc cpu platform sorted"
Router 1 Standby:
Router 2 Active:
Each router has one attachment to customer LAN.
Below the result of a "show platform software punt-policer drop-only"
Router 1 Standby:
Router 2 Active:
Router 1 Standby:
show platform hardware qfp active infrastructure punt config cause 60
Router 2 Active:
show platform hardware qfp active infrastructure punt config cause 11
Thanks in advance for your kind help,
Jerems,
5 Replies 5
Leo Laohoo
What is the WAN speed?
1 Gig Each.
In the meantime i asked the customer to tshoot on LAN side and search for an annoying device which would generate too much Mcast or Bcast frames.
show platform software status control-processor
