High CPU
IrfanKhan4904
 90
 80
 70           *****
 60      ***************                    *****     **********
 50 ************************************************************
 40 ************************************************************
 30 ************************************************************
 20 ************************************************************
 10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....6
             0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
    666665766556766667768766676656866655566666544565465566655555
    845909358977869490533052025151298126625290288608938110456468
100
 90
 80             *     * *         *
 70 * **  ***  *#** *** ***  **   ***     * *
 60 #*#*#*####*####*######***##***#*#* ***#*##   *** #* ***** **
 50 ###############*###########################**##**##*########
 40 ############################################################
 30 ############################################################
 20 ############################################################
 10 ############################################################
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    657765443121223456645655544544422211334655555656566554533222335665578777
    895292924939037710693662662565094098088276238156763858460607020054820994
100
 90
NAMAL-7206#show processes cpu
CPU utilization for five seconds: 53%/46%; one minute: 54%; five minutes: 55%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1       18396     68088        270  0.00%  0.00%  0.00%   0 Chunk Manager
   2        4340    317346         13  0.00%  0.00%  0.00%   0 Load Meter
   3           0         1          0  0.00%  0.00%  0.00%   0 TCP Command
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5     7494572    397338      18861  0.00%  0.42%  0.34%   0 Check heaps
   6         764      2683        284  0.00%  0.00%  0.00%   0 Pool Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  11           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  12           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  13           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  14           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  15           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  16           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  17      131432   1586400         82  0.00%  0.00%  0.00%   0 EnvMon
  18           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  19           8     26446          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  20           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  21         632   1586354          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  22         584   1586354          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  24           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  25      913884   6516332        140  0.08%  0.05%  0.06%   0 ARP Input
  26         604    317335          1  0.00%  0.00%  0.00%   0 HC Counter Timer
  27           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  28           0         5          0  0.00%  0.00%  0.00%   0 Entity MIB API
  29          40      1091         36  0.00%  0.00%  0.00%   0 EEM ED Syslog
  30           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  31         840   1586724          0  0.00%  0.00%  0.00%   0 GraphIt
  32           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  33           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  34           0         1          0  0.00%  0.00%  0.00%   0 TCP Command
  35           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  36           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  37     1335804    796199       1677  0.08%  0.08%  0.08%   0 Net Background
  38           0         2          0  0.00%  0.00%  0.00%   0 IDB Work
  39          16      2163          7  0.00%  0.00%  0.00%   0 Logger
  40        1184   1586342          0  0.00%  0.00%  0.00%   0 TTY Background
  41       40632   1586791         25  0.08%  0.05%  0.08%   0 Per-Second Jobs
  42           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  43           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  44           0         1          0  0.00%  0.00%  0.00%   0 POS APS Event Pr
  45           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  46           0         1          0  0.00%  0.00%  0.00%   0 Coproc Event Pro
  47           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  48           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  49           0         1          0  0.00%  0.00%  0.00%   0 Flash Card Oir
  50           0         4          0  0.00%  0.00%  0.00%   0 TurboACL
  51           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
  52           4        88         45  0.00%  0.00%  0.00%   0 AAA Server
  53           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  54           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  55           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  56    37046268 193927959        191  2.78%  2.91%  2.78%   0 IP Input
  57         244    198347          1  0.00%  0.00%  0.00%   0 ICMP event handl
  58         288    158682          1  0.00%  0.00%  0.00%   0 CDP Protocol
  59           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  60          88    211561          0  0.00%  0.00%  0.00%   0 SSS Test Client
  61           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  62        4244   6198149          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  63           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  64           8      2646          3  0.00%  0.00%  0.00%   0 MOP Protocols
  65           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  66           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
  67           0         1          0  0.00%  0.00%  0.00%   0 TCP Command
  68           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  69           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  70           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  71          56       346        161  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  72           0         1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Redistr
  73         680     50503         13  0.00%  0.00%  0.00%   0 IP Background
  74          92     26704          3  0.00%  0.00%  0.00%   0 IP RIB Update
  75           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  76           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  77           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  78           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  79           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  80           0         1          0  0.00%  0.00%  0.00%   0 IP Traceroute
  81         912   1585840          0  0.00%  0.00%  0.00%   0 Socket Timers
  82        4604    529688          8  0.00%  0.00%  0.00%   0 TCP Timer
  83           0         1          0  0.00%  0.00%  0.00%   0 Transport Port A
  84       50748    131278        386  0.00%  0.00%  0.00%   0 TCP Protocols
  85           4      5291          0  0.00%  0.00%  0.00%   0 HTTP CORE
  86           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  87       18380   3171684          5  0.00%  0.01%  0.00%   0 DHCPD Receive
  88          92     26446          3  0.00%  0.00%  0.00%   0 IP Cache Ager
  89           0         1          0  0.00%  0.00%  0.00%   0 COPS
  90           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  91           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
  92       23028  15798067          1  0.00%  0.01%  0.00%   0 RBSCP Background
  93           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  94           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  95         140     26447          5  0.00%  0.00%  0.00%   0 Adj Manager
  96        7816   2502034          3  0.00%  0.00%  0.00%   0 CEF process
  97           0         1          0  0.00%  0.00%  0.00%   0 AToM manager
  98           0         3          0  0.00%  0.00%  0.00%   0 AToM switching m
  99           0         1          0  0.00%  0.00%  0.00%   0 AToM LDP manager
 100           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
 101        1220   1586360          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
 102           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
 103         448   1586362          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
 104           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
 105           0         3          0  0.00%  0.00%  0.00%   0 gk process
 106           0         2          0  0.00%  0.00%  0.00%   0 Border Element p
 107          32     63471          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
 108           4        88         45  0.00%  0.00%  0.00%   0 LOCAL AAA
 109           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
 110           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
 111           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
 112           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
 113           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
 114           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
 115           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
 116           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
 117           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
 118           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
 119           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
 120           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
 121           0         1          0  0.00%  0.00%  0.00%   0 xcpa-driver
 122           0         1          0  0.00%  0.00%  0.00%   0 http client proc
 124           0      1764          0  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
 125           0         2          0  0.00%  0.00%  0.00%   0 EPHONE MWI BG Pr
 126           0         2          0  0.00%  0.00%  0.00%   0 Proxy Session Ap
 127          60    158671          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
 128           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
 129           4         1       4000  0.00%  0.00%  0.00%   0 SYSMGT Events
 130           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
 131           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
 132           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
 133           0         1          0  0.00%  0.00%  0.00%   0 IMA Traps
 134           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
 135           0         3          0  0.00%  0.00%  0.00%   0 EEM ED CLI
 136           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Counter
 137           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Interface
 138           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
 139           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Memory-th
 140           0         2          0  0.00%  0.00%  0.00%   0 EEM ED None
 141           0         2          0  0.00%  0.00%  0.00%   0 EM ED OIR
 142           0         2          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
 143           8     26447          0  0.00%  0.00%  0.00%   0 EEM ED Timer
 144         256    322073          0  0.00%  0.00%  0.00%   0 EEM Server
 145           0         1          0  0.00%  0.00%  0.00%   0 RMON Packets
 146          12      1084         11  0.00%  0.00%  0.00%   0 Syslog
 147           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
 148        1116   1585806          0  0.00%  0.00%  0.00%   0 trunk conditioni
 149           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
 150           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
 151        7188   1452977          4  0.08%  0.97%  0.54%   4 Virtual Exec
 152           0         3          0  0.00%  0.00%  0.00%   0 Net Input
 153        1084    317351          3  0.00%  0.00%  0.00%   0 Compute load avg
 154      329904     26772      12322  0.00%  0.01%  0.00%   0 Per-minute Jobs
 155           4     13224          0  0.00%  0.00%  0.00%   0 CC-API_VCM
 156       33952  15798274          2  0.00%  0.01%  0.01%   0 CCPROXY_CT
 157         892     55039         16  0.00%  0.00%  0.00%   0 CEF Scanner
 158           0        31          0  0.00%  0.00%  0.00%   5 Virtual Exec
 159      132280 389306261          0  0.40%  0.40%  0.40%   0 IP SLA Mon Event
 160         476    317556          1  0.00%  0.00%  0.00%   0 Track
 161    21230656   4281260       4958  2.45%  2.28%  2.05%   0 IP NAT Ager
 162           0         1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
 163        9612    740422         12  0.00%  0.00%  0.00%   0 IP VFR proc
 164           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
 166        4880     49094         99  0.00%  0.00%  0.00%   0 IP SNMP
 167        1328     24936         53  0.00%  0.00%  0.00%   0 PDU DISPATCHER
 168        5136     24916        206  0.00%  0.00%  0.00%   0 SNMP ENGINE
 169           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
 170           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
 171     6231464 271901066         22  0.49%  0.53%  0.51%   0 NAT MIB Helper
 172          16     26446          0  0.00%  0.00%  0.00%   0 Time Range Proce
 173          28     13223          2  0.00%  0.00%  0.00%   0 DHCPD Timer
 174           4     26451          0  0.00%  0.00%  0.00%   0 DHCPD Database
 175           4       174         22  0.00%  0.00%  0.00%   0 RIP Router
 176           0         1          0  0.00%  0.00%  0.00%   0 RIP Send
 177         400    272933          1  0.00%  0.00%  0.00%   0 RIP Timers
NAMAL-7206#
Leo Laohoo
Let me guess, the IOS version is 12.4(13b) and the WAN link is 400 Mbps.  Am I correct?
Yes.You are correct.
