i'm not able to ping point to point, hence config is all OK.
noob_route
When i try to Ping fron internal router (192.168.40.2/24)to Layer-3 switch(192.168.40.1/24) same subnet ip address, it's not pinging.
NOTE: topology is attached below
Configuration:
INTERNAL ROUTER
redundancy
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 192.168.40.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.50.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.40.1
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
L3-SW
vtp file nvram:vlan.dat
switchport access vlan 10
duplex full
speed 100
duplex full
speed 100
interface FastEthernet1/2
no switchport
ip address 192.168.40.1 255.255.255.0
duplex full
speed 100
interface FastEthernet1/3
duplex full
speed 100
interface FastEthernet1/4
duplex full
speed 100
interface FastEthernet1/5
duplex full
speed 100
interface FastEthernet1/6
duplex full
speed 100
interface FastEthernet1/7
duplex full
speed 100
interface FastEthernet1/8
duplex full
speed 100
interface FastEthernet1/9
duplex full
speed 100
interface FastEthernet1/10
duplex full
speed 100
interface FastEthernet1/11
duplex full
speed 100
interface FastEthernet1/12
duplex full
speed 100
interface FastEthernet1/13
duplex full
speed 100
interface FastEthernet1/14
duplex full
speed 100
interface FastEthernet1/15
no switchport
no ip address
duplex full
speed 100
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.3 255.255.255.0
interface Vlan200
ip address 192.168.30.2 255.255.255.0
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.10.5
ip route 3.3.3.0 255.255.255.0 192.168.30.1
ip route 192.168.50.0 255.255.255.0 192.168.40.2
control-plane
8 Replies 8
balaji.bandi
if the interface up from both the side from Router to Layer 3 switch able to ping.
i would suggest unknow network send to Internet, specific to respected gateways
L3-SW  ( make sure ip routing enabled)
Can you post below output
show interface FastEthernet1/2
show interface FastEthernet0/0
show ip route
show ip interface brief.
BB
Hello
Try:
duplex auto
speed auto
Kind Regards
Paul
noob_route
I didn't do anything, just closed the gns3 and reopend, now it's pinging.
but got new problem, when i try to ping from L3-sw to 192.168.30.1/24 its showing :
Sending 5, 100-byte ICMP Echos to 192.168.30.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
Hello
UUUUU
Looks like external 192.168.30.1 doesn't know how to reach the internal router.
External router
sh ip route
sh ip int brief
Kind Regards
Paul
EXTERNAL ROUTER:
#sh ip route
3.0.0.0/24 is subnetted, 1 subnets
S 3.3.3.0 [1/0] via 10.10.10.1
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, FastEthernet0/0
L 10.10.10.2/32 is directly connected, FastEthernet0/0
192.168.30.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.30.0/24 is directly connected, FastEthernet0/1
L 192.168.30.1/32 is directly connected, FastEthernet0/1
S 192.168.40.0/24 [1/0] via 192.168.30.2
#sh ip int br
FastEthernet0/0 10.10.10.2 YES NVRAM up up
FastEthernet0/1 192.168.30.1 YES NVRAM up up
FastEthernet1/0 unassigned YES NVRAM administratively down down
FastEthernet1/1 unassigned YES NVRAM administratively down down
still we need below output :
show ip route
BB
the problem is that you are trying to connect a physical interface to an SVI. You have three options to make this work (I used physical interfaces GigabitEthernet0/0 in the examples, yours might be different);
Option 1
External Router
interface GigabitEthernet0/0
description Link to L3 Switch
ip address 192.168.30.1 255.255.255.0
L3 Switch
description Link to External Router
switchport mode access
switchport access vlan 200
interface Vlan 200
Option 2
External Router
L3 Switch
switchport mode trunk
switchport trunk native vlan 200
interface Vlan 200
Option 3
External Router
interface GigabitEthernet0/0.200
encapsulation dot1q 200
L3 Switch
interface Vlan 200
L3 for L3SW need to config
ip routing in global to turn on the L3 of L3SW and hence L3SW can use the routing table.
