High input discard rate on interface sc0.
mohammedrafiq
I am getting this error on my 6509 sw, any idea ?
"High input discard rate on interface sc0. The inDiscardRateState transitioned from NOMINAL to HIGH due to a measured value of 1.000322684737012, which is between the lower bound of 1.0 and the upper bound of 100.0. The date and time of the measurement is 2009-02-02T19:37:51.797+0000.
High input discard rate on interface sc0. The inDiscardRateState transitioned from NOMINAL to HIGH due to a measured value of 1.000322684737012, which is between the lower bound of 1.0 and the upper bound of 100.0. The date and time of the measurement is 2009-02-02T19:37:51.797+0000."
Giuseppe Larosa
Hello Mohammed,
one or few packets have been discarded on management interface sc0 going over the lower threshold.
This should be a simple notification if you can still reach and manage the device you can ignore it.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mohammed,
Hope to help
Giuseppe
Giuseppe once again.
