High throughput edge device that does NAT
zadeyoju1
cost effective platform that can push throughputs as high as 3G and also does NAT as well as hardware encryption(excluding the 6500)
ajagadee
Hello Zia,
One platform worth looking into is the ASA1002.
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/qa_c67-452124.html
Arul
*Pls rate if it helps*
Joseph W. Doherty
Arul's recommendation for the ASR series, should meet your performance/feature requirements. Since you also mentioned "cost effective", the 7304 with NSE-100 or -150 might be worth looking at too. (NB: possible issue, VAM or VSA modules might not be supported. There's a Cisco Catalyst 4500 AGM Encryption Service Adapter that's listed but unknown whether it would provide the features or performance you desire nor whether it's correctly listed to work with 7300s.)
