High Utilization on Router CPU (IP Input)
Hi all,
I'm currently having a high CPU utilization problem. I have used "show processed cpu" command and I found that the highest CPU usage is on IP input.
The router in question also have its CEF and Fast switching feature enabled. But unlike the explanation on the documentation, it doesn't solve the problem.
Attached is the config and show command on that router. Could anyone help to point out if I have forgotten to input some command or should I just upgrade this router to the newer version ?
Any advice would be greatly appreciated
Adiputra.
Hi Adiputra,
I had a similar issue in the past.
Since you have ip cef enabled, plese also check that your traffic is also ip cef forwared - e.g
sh interfaces fastEthernet 0/0 switching
Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process   19303316 2574167687    2613648  228138569
            Cache misses        364          -          -          -
                    Fast  276569047 2748504719  192249004 2855311097
               Auton/SSE          0          0          0          0
Check if the counter with the process switched packets increases with a very high rate.
Finally, check if you have many small sized packets (not only unicast but also multicast/broadcast) to router interfaces. This affect the IP input process and this was the root cause of my similar problem with high IP input process. The LAN interface received many small sized packets due to a problem to an end user.
HTH,
Vasilis
Giuseppe Larosa
Hello Adiputra,
first of all, remove usernames / password pairs in the attached file for safety.
I see this is a lab router but these forums are public.
In order to correctly advertise your loopback in OSPF that has a network mask /24 you need to add ip ospf network point-to-point in interface loop1 configuration.
I would point out that there are too much commands in interface gi0/0 and gi0/1 configuration that might be the result of a previous lab.
More specifically your router is only performing NAT currently for all internal addresses between the two LAN interfaces.
interface GigabitEthernet0/0
ip address 192.168.4.50 255.255.255.252
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.0.5 255.255.255.0
ip nbar protocol-discovery
ip nat outside
load-interval 60
duplex auto
speed auto
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 permit 192.168.0.0 0.0.255.255
Taking in account this I would suggest to remove the folllowing commands
no  ip virtual-reassembly
no ip nbar protocol-discovery
interface loop1
After removing these commands you should check switching modes on gi0/1 and gi0/0.
IF this is a lab router you could even try to reload the router if you don't see changes in router behaviour.
Edit:
from the show commands that you have put in the log file we see roughly 290 pkts/sec RX and TX on gi0/1 and gi0/0 and very few broadcast on both LAN interfaces (in percentage compared to total received packets on gi0/0) so the router doesn't look like to be process switching a lot of broadcast or multicast packets that could be a possible root cause as suggested.
Hope to help
Giuseppe
