Showing results forĀ
Search instead forĀ
Did you mean:Ā
HIkvision NVR not pinging from systems vlan1
manoj.puri
i have cisco switch 3560-48 t-s .i configure its port 0/41 as vlan 401 and my vlan 401 int ip is 10.204.27.1 255.255.255.0
and i place nvr ip 10.204.27.2 but when i access this nvr from vlan 1 its not pinging or access
what should be ip address of cameras
stupid question maybe, but do you have IP routing enabled on the 3560 ?
Post the config of your switch. If you have a static IP address, correct subnet mask and default gateway that correspond to the Vlan 401 interface on the switch configured on your NVR, this should work...
