Home Router
miguelv06
I want to get a router for my house. a cisco router im currently using a smothwall router with a d-link n wireless router acting as an access point. I want to do something like this:
Cisco Router -- Smoothwall firewall -- D-link N Router as an AP
I retenlly purchased a 2620XM router and i want to know if this is a good router to do what i want to do... thanks =)
PST: the reason why i want to use cisco in my house is to learn a bit more of it, im currently studing for CCNA
5 Replies 5
kradjesh13
I don't feel there will be an issue if the newly purchased Cisco 2620 router has a DSL Wic in it. I guess you can very well go with your design.
Rajesh
sirdudesly
Level 2
Level 2
You can use the setup you suggested, bare in mind however that there are a few things that make using a cisco router on a home network somewhat tedious.
No UPNP support and somewhat complicated to forward a range of ports make it a bit of a pain if you're using it with things like an xbox or playstation (or bittorrent and the like)
I have two internet connections at home and use a 1800 series router for one of them for educating myself, port forwarding is the main issue I have. It's also considerably quicker than the router it replaced...
I'm not totally familar with the XM series 2600 but don't forget that IOS has it's own firewall as well.
miguelv06
is it worth to put a cisco router in your house?? i have few consoles ps3 xbox360 and wii also i have two servers, providing mail, ftp, domain, etc services
miguelv06
bump!!!!
if you can be bothered dealing with the port forwarding then yes it's pretty good
